How to test my coil to see if it's any good? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2019, 04:22 PM
Last journal entry: '27 roadster quarter panels from scratch
Cool How to test my coil to see if it's any good?
Testing for spark from the coil, I pull the coil wire off the dist cap and turn the car over. Sometimes there is a spark and sometimes not. Does the coil wire terminal need to be close to another piece of metal to see the spark jump or can you see it just by looking into the boot?
I'm thinking my coil may be toast. It's an original '89 Ford piece. How do you test the coil for proper operation?? I have a DVOM.
The coil in question...……………..
Old 01-13-2019, 06:10 PM
the coil wire needs to be about 1/4 to 1/2 inch from a ground like the block
the ignition module likely also needs a good ground through the bolts loading it down, but verify with your wiring schematic
Old 01-13-2019, 06:29 PM
chasracer's Avatar
True Hotrodder
Unless you're just testing a no start or misfire condition - you should just replace the coil and be done with it.
Old 01-13-2019, 08:04 PM
Cool
The terminal is sunk a full 1" inside the terminal boot. Ign module is grounded through a factory heat sink.
I have a strange 'no start' condition. After sitting for 8 hours, the car starts right up and runs fine. Once I shut it off, it won't start again. No spark at the plug wires (terminal 1/2" from plug tip). All plug wires ohmed out good. Replaced rotor and cap. Coil wire ohmed out good. Next would be the coil.
Old 01-13-2019, 08:30 PM
chasracer's Avatar
True Hotrodder
Sounds like an overheating situation where the winding in the coil is expanding, breaking connection - no start. After a period of cooling down time, the connection is good again and it starts.
Old 01-13-2019, 11:20 PM
Cool
Sounds feasible. Is there any way to test it with a multimeter?
rack and pinion how can you test if it is good? amature Suspension - Brakes - Steering 0 03-30-2008 07:10 PM
ow do I check my ecm to see if it is a 350 ecm ghomer Engine 3 12-27-2006 09:51 PM
Have specs, now let see if I can someone to talk coil springs 406chevelle Suspension - Brakes - Steering 7 05-06-2004 06:16 PM
Can you check to see if camshaft bearings are still good in the engine? firewood Engine 8 05-07-2003 03:27 AM
The trip! come see come see Halloweenking Hotrodders' Lounge 72 08-03-2002 02:28 PM
