I always get orange peel! I hate orange peel! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-14-2008, 09:45 AM
Orange Peel is the bane of painting with urethane based auto paint.
Some tips that might help.
Before you spray, use a test card to see how the paint sprays out. I use
the cheap glossy white card available at the local supermarket and cut it to size.
One thing that will burn you is temperature and the surface temperature
of the metal on the car. If the temperature is cool or cold your going to get
caught up in a trap of using slow reducers to try get the clear to flow out.
its been my experience that temperatures in the 70 - 80 degree window
work best. Easy to obtain if your in a booth, not so easy if in certain parts of
the country.
Keep in mind. Temperature is important. Car manufacturers typically bake on
urethane based coatings. The actual baking process helps the paint flow
out.
Base coat orange peel - what should I expect cboy Body - Exterior 9 11-22-2007 08:51 PM
New Paint on car..Halloween colors Black and Orange Peel RodFather Body - Exterior 12 11-03-2007 09:27 PM
Orange Peel in clearcoat duallybuster Body - Exterior 4 03-22-2006 09:53 PM
Removing Orange peel from matt/flat/satin/suede clear? cutting and buffing? myfamiliacc Body - Exterior 3 04-11-2005 01:05 PM
Orange Peel After Sandblasting Festive57 Body - Exterior 11 03-23-2005 08:22 PM
