Hot Rod Forum : Hotrodders Bulletin Board (https://www.hotrodders.com/forum/)
-   Hotrodding Basics (https://www.hotrodders.com/forum/hotrodding-basics/)
-   -   I just want to: install a 5.3 vortec into my 1996 1500 (https://www.hotrodders.com/forum/i-just-want-install-5-3-vortec-into-my-1996-a-471185.html)
19996Silverado 03-14-2017 08:25 PM
I wish it were that easy. I am looking for advice on what I may run into when I try this. I like the HP and torque of the 5.3 vortec. I have one in my 2004 tahoe and love it. I figure it is a good starting point to get my ole truck up and running a little better.
Any thoughts, suggestions or warnings before I start?
Any and all would be most appreciated,
Dan
BuzzLOL 03-14-2017 10:57 PM
If your old engine is the 5.7L Vortec, they can be easily and cheaply rebuilt to 400+ HP...
BogiesAnnex1 03-15-2017 02:56 PM
Originally Posted by hcompton (Post 4108777)
Mounts are totally different and often require some cutting and welding to make them fit. Its not a bolt in in most cases but the trucks have a lot of room may be an easier swap. Not sure what it takes to get one in the 96 truck.
But if your going thru all the wiring and welding to make the 5.3 fit why not go with the 6.0L or 6.2L they make a lot more power and often only cost a touch more. Its also more of a performance setup for a big truck. Chevy's own choice to make the heavier trucks move.
trans will also be an issue. the LS and gen one use a different trans setup. i think its the spacing but getting the 4L80E that is often bolted to the back of the 6.0 is a great trans setup. these can handle 500+ hp in stock form. Like the th400 of the modern world trans. Alot stronger than the 700 or the 4l60.
These take a controller to run but the computer that runs the 6.0 will run them both. These are common pulls from junk yards with engine trans wiring and ecm everything including the gas pedal to make it run outside of the truck.
Another issue is the factory dash may not be happy worth he updated ecm but since the years are close should be able to make it all work with some fiddling. If you can get the full factory setup from a 2500 truck like yours with similar options may make lift a lot easier in the long run. Even if it cost a touch more its worth the money to get the 80e and all the other bits in one shot. Low miles is the next hurtle. But the junk yards all know how many miles are on there engines. But they all come with short warranty and often its easy to find them pretty much any GM junk yard will have the engine and trans combos already pulled. My local in MD used to have them in front of the parts counter. All lined up usually starting with a LS1 or LS3 moving to the truck versions. They could also fire them up sitting right in the parts area. Actually they loved to do it.
One huge mistake I see all the time is people spend piles of cash to get a good deal. A choice between getting a free motor with no manifolds and electronics or getting one fully ready to drop in that cost good money the ready to drop in motor is the deal the free motor will cost way more to get going. If you want to run carb it may be some of a deal but not the way to save money. If you want EFI then there is no other way to do it than buying it complete the wiring and ecm can be another 2 grand if you have to buy every little bit maybe more. Some of these parts are dealer and junk yard only and buying after market complete systems is not cheap by any means.
X2, what more can I say?
To the OP:
It costs a lot of money when you get into these generational changes especially if it has to SMOG. Not that it is impossible to do but the detail changes in the systems takes a lot of time and similar amounts of money to work out.
Unfortunately the injection system on the 96-2002 Gen I Vortec sucks. On the good side is the computer in those will drive the earlier injectors which means with a change to a conventional carb style manifold with injector bungs and a throttle body; the L31 can be converted back to something more like TPI. This gives a better intake than the TPI or MPFI engines with better injectors than the CSFI. The earlier injectors are now operating sequentially. This allows engine mods with various methods of reflashing or external processors, there for the sensing and drivers for the other systems are not affected and except for engine power and transmission control everything else from security to tank venting continues on as usual. These mods easily make a 400 horse 350 under L31 heads. While messing around you might want to consider a 383 kit, it's no more expensive than a standard rebuild and the difference compared to a 350 is like a different universe.
Bogie
BuzzLOL 03-15-2017 03:05 PM
Originally Posted by BogiesAnnex1 (Post 4109697)
Unfortunately the injection system on the 96-2002 Gen I Vortec sucks. On the good side is the computer in those will drive the earlier injectors which means with a change to a conventional carb style manifold with injector bungs and a throttle body; the L31 can be converted back to something more like TPI. This gives a better intake than the TPI or MPFI engines with better injectors than the CSFI. The earlier injectors are now operating sequentially. Bogie
Is there an article available on how to do that, Bogie?
BogiesAnnex1 03-15-2017 05:29 PM
Here's a couple things :
1) This is a conversion actually developed by GM for California vehicles where the CSFI had failed. These are a special designed high impedance injector made to fit where the original pressure valves were installed in the manifold. This shows in a hot-rodder sense that the original injector drivers in the computer box can drive a manifold mounted HI injector.
Vortec CSFI to MPFI conversion
2) Going beyond that I recently made a discover of what I was taking about which was to use a conventional manifold dual or single plane with injector bungs, a Throttle Body that mounts the necessary sensors, driving the injectors off the factory computer. This would use high impedance injectors more of the TPI style than the GM California L30/L31 fix injectors. This unit is from Racing Head Service but is quite representative of what I have in mind.
Small Block Chevy EFI Single Plane Intake Manifold w/ Fuel Rails - Intake Manifolds - Intake Manifolds
Bogie
BuzzLOL 03-15-2017 05:51 PM
Wonder if that MPFI conversion setup can be ordered out with 450 HP injectors!
19996Silverado 03-15-2017 06:28 PM
Vortec 5.3 into my 1996 1500
First, I want to thank everyone for the great threads you posted. There is a lot of good info there.
Now I am asking myself, should I just go with a 350 and build it a little? I was told as long as I stay under 1999, a 350 is a easy swap. I could build a little pep into it with head work, mild cam and such. Do you think this is a better choice? I am not looking to put 400 hp to the rear wheels, just something that will get out of it's own way and be fun to drive.
Thanks again,
Dan
BogiesAnnex1 03-15-2017 07:17 PM
Dan
The 5.3 like all LS engines lacks a distributor. Your 96 has and needs one but its rather unique in that the classic guts aren't in it, the computer is calculating the advance rates.
I found this LS distributor adapter and went ah-ha till I found it mounts a Ford rather than Chevy distributor.
https://www.summitracing.com/parts/nal-88958679
I'm not sure that this a Ford distributor that works the same way the L30/L31 does but if it does and will interface electronically all you need is money.
https://www.summitracing.com/parts/m...view/make/ford
Another way to skin this is with a stand alone LS ignition controller, I'm off the map of things I have done here so I'm supposing that if the controller supplies a tach signal which I'm pretty sure it does and if you feed that signal back into the original GM computer that it will satisfy the computer's view of the world that the engine is running correctly and will fuel it and operate the transmission correctly.
https://www.msdperformance.com/produ...cts/parts/6014
Goes back to what I first said is that when you start crossing these design generations it gets complicated fast and that usually leads to costly in terms of time and money. Not that it can't be done but it becomes a race between the finish line and your credit limit as to which you cross first.
Bogie
vodka0tter 03-16-2017 08:40 PM
im kinda in the same boat with a '97 c 1500 scsb. wanting more than the 5.7 can pump out. i looked at a 5.3 conversion and there are tons of threads/previous conversions out there. you need to swap the PCM as well. I think Painless (prolly others) make plug n play harness as well lots of engine mount, trans mount/adapters as well accessory brackets. prolly need to swap out the a/c if you want to keep it with a custom bracket or notch the frame.
Personaly, i chose to pick up a blue print 383 with 1.6 rockers and work the stock intake. there are aftermarket mpfi injectors (i have a 36lb set up going in). ill port the bottom intake to help (still have the mess called spider injector harness to jack up flow). taylor makes a 1" spacer to go between the upper and lower intake to help the flow. i think i can flow plenty to support the 350ish hp. with larger injectors i feel this would support over 400hp. blackbear tuning and i think ill be on the road to 4l60e destruction soon
matt167 03-17-2017 05:02 AM
Ls based engines into obs trucks have been done and are a great idea if your up to the wiring. The mounts need adapters but they fit and bolt in. Fuel pumps are good enough, and the gauges will work with the ls. But you have slight issues with things like the ac pump and the fact you need a full ls harness from engine you use for a standalone system.
19996Silverado 03-18-2017 02:30 PM
Sweet Info
I am hunting for a nice 5.3 vortec now. I have on in my 04 Tahoe. It has 258,000 miles on it. I have used synthetic oil since day one and still has a oil pressure over 40lbs after warming up so I am tempted to pull that and rebuild it. My wife may not like that idea lol, so the hunt goes on!
Dan
matt167 03-18-2017 04:17 PM
The 6.0 is the one everyone wants. They will bring the most. The 5.3 is probably the most popular due to coming in more trucks. And the 4.8 is the one that is dirt cheap. They are regarded as black sheep but, they make more power than the 5.7 vortec and will get better mpg. If your truck is a 5.0l its even better.
bullheimer 03-18-2017 07:17 PM
funny, i was thinking, about the same thing but now that i read Comptons post 2, i can think about something else.
64nailhead 03-19-2017 08:01 AM
There's only one way to do this cheaply, and it's with a complete donor vehicle. And of course it's a must that you have some decent fabrication skills. Using a different trans, ECM, ignition, etc, becomes salty in a hurry.
The OP mentioned this is in a K1500 - 4WD just adds onto the expense and fabrication.
matt167 03-19-2017 06:02 PM
There is more than one way to skin the cat. The OBS trucks are not intergrated like newer trucks are.
One way is to splice in an 0411 PCM into the OBS truck and find and adjust the wiring to the engine/ trans as needed. Many temp or sensor connectors are the same. That's the way you can make it look totally factory if the connectors are re pinned, rather than cut/ spliced.
The easiest way, would be to buy or build a standalone harness for the engine. They really hook up to power with 2 or 3 connections once they are modded and programmed for standalone. Place the OBD connector where it was originally ( the trucks mount the same ) and wire the gauges up. Need to read a diagram or 2 for wire color but, they are electrically identical. The original PCM won't do much at all but complete the trucks electrical system, and the standalone will run the engine/ trans..
I would go for a '99-'01 engine as they were still cable throttle.
