ID a T-10 BW transmission?
How can I identify a T-10 Borg Warner transmisión for a 1966 Mustang GT350 without disassembly the transmission
Sponsored Links | |||
Probably your best bet is to call and talk to David Kee. He is the Ford Toploader specialist, so I suspect he has considerable T-10 knowledge as well......
SiteMap |
Moved tech question to the main forums.
Dont worry how old you are... it is the mileage on your body that adds up. |
Sa t 10
I was an engineer at Ford back in the day
If my memory is correct the Shelby used an aluminum csse T 10 close ratio with a 2.36 first gear ratio. different from regular mustangs. you should be able to get more info from the Shelby American car club. |
turn the shaft
shift it into first gear and turn the input and count the turns to get one turn on the output/
Thanks to all of you for your comments
Recent Transmission - Rearend posts with photos |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
