I'll try to be clear. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2008, 06:03 PM
Stovebolter's Avatar
36 Chevy Low Cab
Last journal entry: C4 IRS
I'll try to be clear with my question. In the attatchment you'll notice there is a relief (1/4 valley) all the way around the fire wall about 1" forward of the bead where the rear of the hood meets the cab. ( ) If that wasnt confusing I dont know what is. LOL's. Anyway...I assume that is for a piece of weather stripping...I'm picturing a sort of rope that is attatched via the hole at the bottom then stretched around to the top? Can anyone help? I've concidered filling the valley (spot welds) and instead using a sticky backed figure eight weather strip, from someone like Softseal, placing it behind the hood so its not noticeable when the hood is raised?
Thanks,
Dave G
Old 10-12-2008, 11:52 PM
327NUT's Avatar
Yea you're right it was confusing.......not really if you know what to look for. Your idea sounds good and will probably work ok but some of the stick on rubber pieces seem to loosen up or lose the adhesiveness (is that a word?) over the years. It would seal better than the old rope looking piece, all depends on the look you want. I wouldn't fill the holes though, just cover them if possible with the rubber seal.
Old 10-13-2008, 06:27 AM
36 Chevy Low Cab
Thanks....believe me...I dont want to have to fill the void. My trouble is...I had to replicate the lower front cab corners because the originals were literally gone. One of the previous owners really like plastic filler. I started with new steel and formed it the best I could. Wasnt easy duplicating the body line at the bottom....affraid its going to be even harder to duplicate the valley I'm talking about. How did the factory seal work? The way I imagined it does?
Dave G
Problems with clear; fisheyes, never dries joewhite Body - Exterior 4 10-01-2006 06:05 AM
Can you respray clear over dried clear.. makaveli200369 Body - Exterior 9 08-21-2006 07:46 PM
Clear, No Clear, or Clear + Base? tallpaul Body - Exterior 16 01-21-2006 05:30 PM
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 02:52 PM
base coat clear coat wally Body - Exterior 8 12-12-2005 06:44 PM
