Importance of treating hood and trunk braces - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2014, 12:16 PM
Pats55's Avatar
14 years ago I painted a 55 Chevy hardtop The entire car was primed with Mastercoat Permanent rust sealer,DuPont fill and sand,And Centari.I never really finished painting the car, I put some color on it to see where I was at but I drove for 14 years. I noticed a small bubble at the bottom seam of the trunk.This is usually the first place that paint jobs go bad. I had treated the seam when I first painted the car. Upon closer examination the bubble was about an inch above the seam, I never bothered to spray up inside the braces. When we cut it out. I was surprised on how much rust was in there. I guess I was in a hurry. Were my treatment ended. The rust began. There is also a bubble under the brace on the hood.So now remove the trunk and hood. This is how I treat them. Turn them both upside down and flood them with a good phosphoric acid rust remover like ospho, rust mort or my favorite master coat.After the rust is been treated somewhat dissolved I'll let it dry out and then spray the mastercoat sealer with a want sprayer. Hopefully this will go another 14 years.For you nonbelievers you can use your epoxy primer too or Corroseal, Anything is better than nothing
ID:	177402   Click image for larger version
Name:	hoode brace 012.JPG
ID:	177418   Click image for larger version
Name:	hoode brace 011.JPG
The Following 2 Users Say Thank You to Pats55 For This Useful Post:
cerial (10-20-2017), John long (10-16-2017)
Old 10-16-2017, 07:53 PM
Car Nut
I used a Wurth cavity wax gun that I have on some 356 rocker cavities. Ended up cutting the rockers and pan out at later date. I was very disappointed at the lack of coverage that I actually got form the spray. The idea is similar to the one shown in the Eastwood add you posted. All I can figure is that once inside the thing is probably resting on its side and not really spraying in all directions. Plus since you can't really see what you are spraying hard to know what when and how much. But probably better than nothing. But as mentioned above, having to weld around that crap is a [email protected]$&tch.
Old 11-19-2017, 07:36 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
The cavity wax wont do anything if rust is already there it might even make things worse by trapping moisture, it works good on new rust free stuff though and prevents rust from starting. You cant just cover rust up.
Old 11-19-2017, 09:31 AM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
A Rust encapsulater works very well, for sure the Eastwood products do.
Old 11-19-2017, 10:18 AM
Car Nut
Which Eastwood product are you specifically referring to? What is your experience with it and how did it perform?
Hood and trunk alignment tip, for you pros too! MARTINSR Body - Exterior 55 09-30-2012 09:28 AM
Hood or trunk installation tip. MARTINSR Body - Exterior 6 09-25-2012 10:33 AM
Bumps on hood and trunk? Mad_Max Body - Exterior 10 09-02-2009 06:50 AM
looking for trunk braces steve123 Introduce Yourself 1 06-17-2007 02:41 AM
hood braces? newchevyman Body - Exterior 3 01-11-2004 02:50 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
