Initial alignment specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2019, 08:29 AM
I am building a '48 Ford Coupe with a MII front w/power rack and MII control arms/springs. I'd like some input from anyone with the same setup as for the initial specs for alignment. Would the specs for the original Mustang II be close? Thanks in advance.
Old 08-14-2019, 03:38 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Who made the MII parts? That's who I'd be looking to for alignment specs.
Old 08-15-2019, 07:14 AM
Ford. Mustang II control arms, ball joints, Lincoln rack. Conversion from Speedway.
Old 08-15-2019, 07:48 AM
S10xGN's Avatar
Gotta love a turbo!
Be careful, there's a huge difference between a true Ford-made MII front end and aftermarket "clone" suspensions. As a rule, the aftermarket stuff use "MII" as a description only, very few actual Ford parts will interchange. Most of the aftermarket stuff is higher in quality and load capacity too, due to 40 years of improved technology...
Russ
Old 08-15-2019, 08:05 AM
bentwings's Avatar
bentwings
Here is a tool I used for my initial set up. Then later to fine tune my Willys Must ll front end. It’s easy but maybe not the most accurate without turn plates. I just put soapy water under the tires.
Most Streetrods have some forward rake or down angle on the front. This changes the caster angle a bit so you have to compensate for this. I just used the stock setting then measured the forward rake and added this in. It worked pretty well initially.
The Willys didn’t have much body roll with the anti roll bar in front and the very stiff one in the rear so I varied the camber setting to suit my driving. The front tires didn’t wear as well as I liked and winter storage eventually caused a ply separation. But front tires were a lot less expensive than the big Hoosier rear tires.
We also use this tool occasionally on trailer repairs.
Longacre has all kinds of alignment tools.
Longacre Caster Camber Gauge 78272
The Following User Says Thank You to bentwings For This Useful Post:
snappy347 (08-15-2019)
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
