Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Intake air temps are way too hot.
Old 08-10-2019, 02:55 AM
Dfish1247 Dfish1247 is offline
You have turbulence there being the air goes from coming sideways to turning down into the carb. But, the hat would have to be tiny to gain 125+ degrees in 10 seconds. Are the intake runners flaming hot as well?
If you have a wastegate on the turbo, you could back the boost down and see if there's a point where you stop generating so much heat.
Boost is just a pressure reference after all, more pressure=more heat.
