Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Intake air temps are way too hot.
Old 08-10-2019, 09:54 AM
Pupsvette76's Avatar
Pupsvette76 Pupsvette76 is offline
Last journal entry: no spark and fuel pump issue
So it’s an 88mm turbo making 20psi and it makes around 870hp. I do believe I need a more efficient intercooler but the reason I’m not really worried about it specifically is because where the heat really is is at the carb bonnet. On the topic of the cArb bonnet it’s not as smooth flowing as it could be. Sort of a tight turn it’s a spectre carb bonnet. I do have a water meth setup partially installed on the car I guess it’s time to use it. I also plan on switching to e85 because I currently run ms 109 and it’s too expensive not to mention the cooling I could get from e85 would be great.
