Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Intermitent Brake pedal feel
Old 08-11-2019, 06:51 AM
55 Tony's Avatar
55 Tony 55 Tony is offline
Originally Posted by joe_padavano View Post
If the ABS light does not go on, there are no codes to read. Most of the problems with the brake system will not set a code. Check for bad M/C, bad booster, bad flex lines, or bad caliper.
Thanks. Already replaced the master cylinder and the booster. I'll check the calipers for sticking. What could the flex line do to give it that symptom?
Young enough to learn ... too old to remember.
