Just curious about roller painting - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2010, 07:16 AM
Old Fool's Avatar
Many threads are posted about using garden store paint and a roller on a vehicle.
What I wonder is for a $100 more they could be using automotive paint. I assume that the automotive paint would be more durable than the wheelbarrow paint, even though it wasn't applied as per manufacturers recommendations.
Anyone have any experiance doing it this way?
Lets try and keep this thread based on facts, not emotions.
I am not advocating this technique in any way so don't flame me for asking !
Myself,I'll stick with my Iwata.
Old 05-28-2010, 08:08 AM
If you read my threads and posts at all you know that I will try goofy stuff like this and give it an honest look. I did try to roll on urethane clear using the best hightech foam rollers and it was a miserable failure.
The biggest problem is the air bubbles that get "whipped" into it as the roller goes across the surface. There may be some trick to using super slow reducer or some damn thing but as I saw it, it was a failure and I don't believe it can be done with any success.
Old 05-28-2010, 08:25 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Automotive paint is not formulated to be brushed on any use of a brush would be difficult at best..Saying that I have brushed a bit of primer on a sand thru when I did not want to go thru gun cleaning and all that..
The brushes used for yacht work make that iwata gun look cheap and doing fine work with a brush or roller is a whole nuther world..
Be it noted that auto refinish is oreintated to the needs of a collision shop where speed is of the essence so auto paint is made to dry or cure fast so in order to brush it one would have to do something to slow it down a lot in order to maintain what we call a wet edge that makes paint suitable for brushing..
Sam
Old 05-28-2010, 08:38 AM
seen my unkle brush on red enamel back 38 years ago and he fine sanded and buffed it , glass look after doing .of coarse it faded out after a few years .
Old 05-28-2010, 08:41 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
it is called tipping. it is what skrimshaw was talking about last year.
Old 05-28-2010, 09:40 PM
Many years ago I bought a car that had been brush painted.
It seemed to be automotive acrylic enamel, and it looked real good for being
brushed, wtih very few brush marks, and with some sanding
and buffing would have rivaled a spray job.
I wonder if a foam brush would do a better job than either a roller or
bristle brush? Would the paint solvents attack the foam?
I think the trick is to use a very slow reducer and lots of it.....
Old 05-28-2010, 10:39 PM
Sam
When I was with Martin Senour we had a Marine line. It was a urethane SS and had a "Brushing converter" as part of the line. Never used it, never sold a can of it as I remember. But I wonder...hmmmmmm
Old 05-29-2010, 12:50 AM
Wiki Edits: 31
I think it would need a thickener rather than a thinner which I don't think exists .. I think that's why Rustoleum can look so good ( at first ).. thicker paint, that will gloss nice, and it's very hard and goes on thick so with a cut and polish, it'll look like it's sprayed.. only downfall is.. everything else a paint should be it is not...
with my '51 Chevy, my siphon feed primer gun would not pick up the primer to spray the roof, so I got out a foam roller and rolled the epoxy on and went thru 3 rollers because it ate the glue off of the cardboard
Old 05-29-2010, 03:55 AM
A friend and I used a brush-on bed-liner on his '72 tow truck. The truck was abused over the years, and the bodywork necessary to get it straight enough to paint "normally" wasn't worth the effort. After sheetmetal/bondo/cheesegrater work (no sanding), we brushed it on. Couldn't even tell there was unfinished bodywork under it...brushed on bed-liner blends-in all the imperfections. Of course, it had a gritty/flat-black appearance...but it took only an afternoon of work. And it held up for years until he sold it.
Old 05-29-2010, 07:04 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
how about a paint stick .
Old 06-07-2010, 10:27 AM
first off dont shake the can tipical mistake good to see you tride it tho.most people complain with nothing to back it because they wont try it.
Old 06-07-2010, 10:38 AM
yea today's oil based enamels are better i prefer the pro series rustoleum its oil based enamel has a really good shine to it and is UV protected also don't put a clear coat on this stuff the clear coat will peal off after a year nothing to stick to.but the paint will last a minimum of 5 years. but you should wax it once a year with tirtle wax.
Old 06-07-2010, 02:07 PM
Underground's Avatar
Last journal entry: 54
" PRO Series"? WELL, that changes EVERYTHING!
Old 06-07-2010, 05:09 PM
BarryK's Avatar
LMFAO.
Yes, that pro series changes everything, I just hope they did not put "For professional use only" on the can , so I can qualify to buy some.
Hydraulic cams - flat versus roller - revisited hotrodf1 Engine 21 12-07-2012 03:37 AM
flat tappet to roller cam HP difference sooper Engine 12 04-20-2010 12:04 PM
Would roller lifters work without a roller cam? DEMONSPEED Engine 4 11-08-2009 04:44 AM
Painting flat black with a roller fiscus Body - Exterior 21 06-10-2007 09:01 AM
solid flat tappet v/s hydraulic roller 406 ss monte Engine 8 10-31-2006 08:29 AM
