I was away from home and when I returned home I heard compressor running in garage. I thought that it bled down pressure and started running to build it up however when I checked ball valve was shut and there was no air leaks that I could hear.
There was a burning smell and pump was pretty hot itself, oil is full. I took off air cleaner and it looks like/smelt burnt. Compressor itself works but doesn't build up pressure. What could be problem. Don't want to buy entire whole pump if I don't have to, would rather rebuild pump myself if I have to.
Compressor is Kobalt K7060HFV
Pull the line where it goes to the tank , if you get pressure from the compressor , then the check valve is stuck/failed , if no pressure , it's time t dig into the pump ..
dave
oil less, right? very simple to rebuild, flap valves and a ring, maybe a couple needle bearings. you'll laugh when you see the ring. check the one way valve going into the tank too but it sounds like the pump is fried.
Yes, assuming the piston(s) are still going up and down, something caught in a simple reed valve and holding it open or they're loose or they're broken off... look for them just below the air cleaner... they flex and let air in, don't let it back out, when working right...
Should turn compressor off when not around it or using it for any length of time...
You have intake valves (to keep air in the compressor) and exhaust valves (to keep air in the tank) just like an engine and both have to be working right...
Copper (I think its copper) gasket must've oveheated and blew apart. I wonder if I should apply new gaskets and reassemble it or I need to swap out valve plate?
One thing I always do whenever I'm gonna be away from home more than a day, I turn my compressor off. I'd hate to think what would happen if a line blew and that 7.5 HP motor kept running trying to make it up. I keep seeing the garage going up in flames...
Yeah, every day when I leave I turn off the main and shut EVERYTHING down. then turn off the air tank valve. when I come in I turn on the valve and the breaker and get going. Sooner or later a line will bust so you really need a shutoff valve, plus it'll save a lot of cash not having the compressor start up and build pressure every morning of every day, not just in electricity but wear and tear of the compressor.
valves and ring and another gasket will fix it. Think of it as an engine with no compression theres only three things that could be wrong, you've eliminated one of them. but I've never seen one blow a gasket.
since its not an oil less comp its most likely the flap valves because they are usually thin metal that warps if they get too hot and lose thier seal so when you pull the head off place your hand or something over the cylinders one at a time to see if its got compression at the cylinders if not you need a ring also. I can tell by the blued head the valves are toast last pic of post 10 ,they got very hot so if your lucky you only need valves. but it will need valves. check the compression at the cylinder with the head off and you'll know if you need to order a ring.
Part 0001 is the valve plate with gaskets
Part 0012 is a ring kit for one piston
The valve plate and 2 ring kits would be about $113. The complete NS18S pump is $204. If that is the pump it uses, the complete pump would be a far better way to spend your money as compared to buying the parts for the old one. If the rings are shot then you'd likely need to run a hone thru the cylinders to break the glaze and assure new rings would seat. Honing requires that you completely disassemble the compressor. Otherwise, junk from honing will end up in the bearings on the crank and they'll be gone soon too. Spend the extra 90 bucks, bolt it on, and your compressor is essentially brand new.
Had valve plate reversed, took it off and reinstalled and compressor is building up pressure now and shut off at ~125psi like its supposed to. Is there supposed to be oil on top of cylinders? When I took off valve plate it had a bit of oil on it.
Reed valve upside down... glad to hear it... figured it was something simple now... should have wiped the oil off... it was from overheating and pumping without building up the pressure that usually keeps the oil below the rings...
I just finished a rebuild on my DeVilbiss 60 gallon compressor that has literally thousands of hours on it. I was seeing some foamy oil in the water when I drained the tank at the end of the day. Although the rings looked fine I replaced them along with the reed valves and gaskets. I had the crank polished while I had it apart too. The whole shooting match was less than $100 and it runs like a brand new compressor now. Much quieter and quicker to build pressure.
If you decide to replace the rings (and I strongly recommend you do) be sure you run a hone in the cylinders to break up the glaze. The only thing special about "compressor oil" is that it's a straight 30 weight oil without any kind of detergents in it. If you run a detergent oil you'll get a heavy carbon like build up on the reed valves which will eventually cause them to not seat properly. Ask me how I know.
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
