Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Leaf spring
Thread: Leaf spring
Old 04-09-2019, 12:55 PM
39 master's Avatar
39 master 39 master is offline
I had about the same problem with the '39 and enough blocks to put the U-bolt ends to close to the ground. What I did was to switch to air bag rear suspension so when people climb in the back it's just a push of the button to level the ride again. Other times I used a local truck spring shop to re-arch the springs and they were spot on. Might consider adding a leaf if necessary.
