Led shop lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2019, 06:46 PM
oldcpecdr's Avatar
Led shop lights
Hi all
Any suggestions for HARDWIRED LED shop lights ?
I have 8 old school fluorescents to replace that are hardwired.... almost all of
the LED's I am seeing are plug in. Anyone used a good hardwired LED that
won't break the bank ? I need four footers,
Thanks
Mike B
Old 02-01-2019, 10:41 PM
39 master's Avatar
Shop lights
I installed 2 three footers from Lowes for $20 each and they do the job of 4 four foot flourescents. The newer surface mounted LED lights really work well. Only problem is that when you enter the dark shop and turn the lights on it's instant bright, not the gradual lighting of other types of lights.
Old 02-02-2019, 07:13 AM
Fang16's Avatar
Last journal entry: Project change
A friend put some in his shop with a built in bluetooth speaker system.Thank he got them at Lowe's?
Old 02-02-2019, 07:48 AM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
Originally Posted by 39 master View Post
I Only problem is that when you enter the dark shop and turn the lights on it's instant bright, not the gradual lighting of other types of lights.
That's a problem? That's really splitting hairs is it not?
Back to the OP, Yes I have hard wired 15 fixtures, 30 tubes. Easy as falling off a log, left the ballast in the housing.
Now up for 2 years, not one tube failure, highly recommend the up grade. And no to be very clear I 'm an IT guy & home HotRod builder, & machinist ... no skin in the LED game .
https://www.superbrightleds.com/cat/...acement-bulbs/
I purchased the tubes form the link added ...
I can also explain ... or cut thru the chaff seen from the U-Tube experts that seem to always make simple things. Confusing trying to puff up the level of their not so intellect.
Pep
Old 02-02-2019, 08:11 AM
55 Tony's Avatar
I'm not sure exactly what you want but I had 4' florescent 2 bulb fixtures. I bought LED bulbs that fit right in but you have to rewire the fixture to put direct 120vac to one end of each bulb and throw out the ballast. I really like them, bought them on Amazon. I could find them if you are interested.
Young enough to learn ... too old to remember.
Old 02-02-2019, 08:47 PM
oldcpecdr's Avatar
LED Sop Lights
Thanks for the replies.
Going to order some retrofit LEDs that use the existing housings but throw away the old ballasts.
Looks simple enough to wire and a lot easier than taking down and then replacing the old fixtures.
I will post some pics when done.
Thanks again
Mike B
Old 02-03-2019, 05:42 AM
55 Tony's Avatar
Make sure you get the color you like. Some of the daylight ones hurt my eyes and I can't see well with them. Then others are really yellowish. Sorry I forget what "Kelvin" mine are, it's just a tiny notch down from the daylight ones.
Old 02-03-2019, 08:06 AM
rip-tide's Avatar
Cool 5000K = jewelry store bright
Natural 4000K = as you see
Warm 3000K = yellow hue, or somewhat dimmed
Cool: being the brightest, photographs with a blue cast, and washes out color.
Natural: sun light, photographs well, even light spectrum truer color
Warm: dim low light, mood, photographs are dark over all
Hope that helped.....
At first went for the Cool, but backed off and find the Natural suits the shop best.
Seeing/viewing the correct color carries more weight and has a larger influence than we realize. I became aware of this because I take pictures of some things I make.
.02
Pep
PS: you get rolling, depending on the ceiling hight. Can hard wire those fixtures with out pulling em down, it's that easy. Really makes no sense to remove the ballast, unnessary in the big picture.
The Following 2 Users Say Thank You to rip-tide For This Useful Post:
22george (02-03-2019), Molon Labe (02-12-2019)
Old 02-03-2019, 08:45 AM
55 Tony's Avatar
Yes, I just checked mine,they are 4000 Kelvin color. I have some that are clear and you see each LED and some later ones that are frosted. I like the frosted better. They are Hyperikon brand. Use them a lot for years and no failures yet.
Old 02-09-2019, 04:31 PM
I got the 8ft hyperikon brand and replaced about 50 fluorescents, in some places I used only 1 LED to replace 2 fluorescents. Get the ballast out now, they can fail too. I love the them.
Old 02-09-2019, 06:03 PM
just a couple of questions
how do the LED hand the cold?
Ive got some 8' florescent bulbs in a poorly insulated shop that take for ever to warm up and light up, they are single pin
is there a retro bulb for them?
Thanks
Old 02-09-2019, 06:07 PM
55 Tony's Avatar
The LED lights go to full brightness instantly even at temps well below freezing. I'm not sure if there is an 8' version, try google.
Old 02-09-2019, 06:59 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
Yes.. I have bought 16 of the 8 foot long single pin lights from a place called Green Light Depot. I believe they are in Georgia.
My tubes are 5k light color, 4400 lumens, clear lens. Work very well on my 13 foot high ceiling shop.
I removed the ballast device, straight wire to 110v
The Following User Says Thank You to Crosley For This Useful Post:
palmersparts (02-09-2019)
Old 02-10-2019, 04:57 AM
Buckeye Bob's Avatar
you will really be happy when you change over to leds.i have 8 4ft double tube lights that i changed over to leds.it is really easy to do.GET RID OF THAT BALLAST.i like the daylight tubes.boy what a difference.if you want 8 ft,put 2 of the 4ft close to each other.there is nothing like them.no matter what the temp.is they always come on instantly.and you save a lot on your electric bill
Old 02-10-2019, 11:51 AM
jaw22w's Avatar
My shop is 36 x 30 x 9. I started out with 3 rows of (3) 4' 2 tube fluorescents 32 years ago. Good for young eyes. Got a little older and changed to 3 rows of (3) 8' fluorescents (18 tubes). I then replaced them in the same configuration with 8' fixtures each containing (4) 4' led tubes. (36 tubes). Holy cow! What a difference! I have been in operating rooms not as bright as my shop is. Great for old eyes. Probably about half the cost for juice.
One thing I have not seen mentioned is the longevity. I used to be replacing a fluorescent tube here and there all the time. I haven't had an LED go out yet. Going on three years.
Oh yeah! You can not have too much light. Even with the bright light in the shop I still find myself wearing my headlight at times. LOL
The Following User Says Thank You to jaw22w For This Useful Post:
64nailhead (02-24-2019)
adding LED parking lights to license lights? matt167 Electrical 2 07-17-2017 03:40 PM
wiring led pilot lights? there 22mm panel lights matt167 Electrical 10 07-30-2015 03:17 PM
Hand Held Shop Lights (LED vs. Fluorescent) 64Joker Garage - Tools 16 11-26-2009 06:39 AM
Custom LED tail ligths, how to bundle led's? Augusto Electrical 3 03-03-2009 12:30 PM
LED tail lights, third brake lights ? 1 Day Electrical 6 02-18-2006 06:33 PM
