Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - LED tail lights stay partically lit
Old 06-26-2007, 05:53 PM
docvette docvette is offline
Last wiki edit: Rebuild an alternator
Wiki Edits: 12
Doc here,
Check to be sure your not getting a reflection off something else..LED's will do that and look to be lit..
IF they actually are getting power from a source after shut down, Look for a Cap in line with the array, It may not be draining off right away, and holding the LED's on..If that's the case, you'll need a bleeder resistor to siphon off power after shutdown.
BRIAN:
Actually , an LED is a Diode..(Light Emitting Diode) If you counter oppose it with another diode you may end up with a "Crude" Gate..that you can't forward bias to turn it on..(that is a trial and error thing..)
Doc
