Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - LED tail lights stay partically lit
Old 06-26-2007, 07:08 PM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
The LED is definitely lit...and not getting a reflection. As soon as I disconnected the battery the lights went off.
What is that "cap" in the line that you mentioned ("Look for a Cap in line with the array")? And where do I go to get a bleeder resistor? Is that something an auto parts store will have or do I have to find it in and electrical supplier?
I should also mention that the LEDs were lit a good 24 hours since the truck was last driven so could that still be the drain off situation you mentioned? That seems like an awfully long time but I know absolutely nothing about electrical gremlins.
Always learning...and sharing what I've learned.
