Originally Posted by zippi
It is the front right turn signal. When I turn the headlights on it lights up. It's just the turn signal will not work. Think maybe under the steering wheel the turn signal switch could be bad? The steering column is out of a 84 Chevy truck.
This sounds like a grounding issue with the headlights to where they are finding ground through this turn signal bulb. I'd do a real good check on the head lights to be sure they and the framework supporting them is well grounded to the chassis.
Bogie
