Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lexan windshield install
Old 11-08-2018, 05:11 PM
chasracer's Avatar
chasracer chasracer is offline
True Hotrodder
One issue you will have is the depth difference and assuming you are not using the stock window trim. If you 're putting in say 1/8" stuff and the windshield frame is 1/4 deep, you need a spacer. You can take strips of extra lexan and make spacers. Second item is drilling the holes for mounting. it depends on the curvature but spacing is between 2 and 3 inches. Best way I found was to take masking tape and marking it with a sharpie, then applying the masking tape to the lexan. Oh and keep the plastic protection on it until you are finished. Also if you want a black edge around the window, I found that Krylon was good and easy to do. On the backside, I marked off how wide I wanted the edge and then lightly went over it with a razor blade. Remove the protective sheet from that area being careful to not lift the protection from the rest of the window. New razor blades are a must! Anyway, lightly scuff it with a 3m pad and then shoot it with the Krylon. Two thin coats are about all you need.
