Looking for some advice on my 350 build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-01-2015, 10:12 AM
I forgot to mention the motor is strong. It only has about 20k or so on it.
I don't really want to pull the thing and do bottom end work, and I mostly want to give it some top end goodies for some better power. Is that an unwise desire?
  #17 (permalink)
Old 02-01-2015, 10:43 AM
jokerZ71's Avatar
Wrench Turner
Standard SBC deck hgt can range from .025 to .030.As suggested above,take a measurement after pulling the heads & inspecting everything else.Vortecs on a stock short block using a .015 gasket will generally put you in the 9.5:1 range.Advertised chamber volume is 64cc.In reality,they tend to run a litlle smaller in the 62 cc range.
  #18 (permalink)
Old 02-01-2015, 01:29 PM
That's good news for me. Thanks for that info
  #19 (permalink)
Old 02-01-2015, 01:49 PM
jokerZ71's Avatar
Wrench Turner
If your short block is good,Vortecs setup with proper springs,a Comp or Lunati 262 or268 cam,.015 gasket,4 bbl carb of your choice & free flowing exhaust will hit your power goal with good drivability.A proven recipe for a 350.
  #20 (permalink)
Old 02-01-2015, 02:26 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Here's the problem:
If you have not owned the motor ever since it was produced on the Chevrolet assembly line, then you have no idea what has been done to it by its previous owners. The decks could have been cut already or the last builder could have used those fosdick rebuilder pistons with a 1.540" compression height that puts the piston crown down in the bore by another 0.020", wrecking any chance of getting a good squish/quench.
In the first place, these motors are mass produced and although they have a set of standards, plus and minus, the block deck height could be anywhere from (for instance) ~9.015" to ~9.035". All it takes is a small chip in the register of the mill that the operator failed to clean out from the previous block that was cut in the mill to make a heck of a difference. The other thing about milling the block at the factory is that you have no idea if both banks were machined the same from the centerline of the main bearing bore. Matter of fact, is you find a block that has the same centerline to deck dimensions on all four corners, you should run right out and buy a lottery ticket. If the block is milled askew, then you would have 8 different static compression ratios, a different one for each cylinder.
That's the whole idea of building a motor. You use blueprint dimensions from the factory or other sources to equalize everything, so that A works with B and B works with C and D. First, you inspect the main bearing bore for all holes being round and parallel with each other. If they are not, you correct them by the align honing or align boring process. Once the mains are valid, you measure the block deck height at all four corners with a 12" dial caliper. If the decks are all the same and the block deck height falls into place for the stack of parts you will be using, fine, build it. But is the decks are off, like I said, you will have 8 different static compression ratios, the heads will sit askew on the block and the intake manifold doesn't have a chance of sealing up properly on the heads.
The least a fellow can do is to pull the heads and measure the piston deck height. That will tell you what gasket you should use, or if the piston deck height is excessive, or the measurements are off from the front to the rear of the block, it will tell you that the motor should come apart to cut the decks so that you can engineer a proper squish into the motor and to have the same static compression ratio on all 8 holes.
The Following 2 Users Say Thank You to techinspector1 For This Useful Post:
Mike85 (02-04-2015), vinniekq2 (02-02-2015)
350, build
Chevy 350 build, Advice? Mikes1500 Engine 44 08-22-2014 10:11 PM
Advice on 350 build atc529r Engine 46 09-15-2013 01:40 PM
350 build advice El Rob Hotrodding Basics 28 04-19-2013 03:52 PM
Need advice 350 build. oldhotroddertr7 Hotrodding Basics 4 10-18-2011 03:18 PM
350 build advice 75chev4x4 Hotrodding Basics 1 01-17-2011 12:54 PM
