looking for A switch? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2017, 10:47 AM
bsa_bob2's Avatar
This is a picture of my ole "Milwaukee hand bandsaw' thats been with me 40 years i guess. Helped build many; hotrods muscle kars Kustoms .Needs parts. I have tried about everywhere but nothing turns up,for this switch
Jus "discont"; shows up on the screen. I thought i would try here- maybe one of you fellas has a "parts -bandsaw" ---model 724--ser#76107 or even a switch- you aren't using. I told her i don't need to spend the money on top quality new tools, at my age 73.She agreed 'of course. Thanks for reading this post bob s ~~~~~any help genuinely appreciated .
Name:	miluakee band saw 001.jpg
ID:	377673   Click image for larger version
Name:	miluakee band saw 002.jpg
Old 09-17-2017, 05:27 PM
Wiki Edits: 31
Since it's of the type a drill uses. I'm going to guess that a Rockwell drill from the same era uses a switch that is likely the same. Those drills are not hard to come by and an electric motor place that has been around. probably has some parts
The Following User Says Thank You to matt167 For This Useful Post:
bsa_bob2 (09-21-2017)
Old 09-17-2017, 09:44 PM
Rip VW's Avatar
Last journal entry: This thread is officially Kaput as of 11/07/2017
Here is a simple fix maybe,
measure the width and height of your oem switch. Go to the hardware store electrical dept and look for 115vac rated momentary contact push-button switch. You should be able to find a switch that will set in the space occupied by the old switch. you could mount that switch on a small metal plate you could use in the space the previous, Presto for a couple a dollars your back in business. Not oem but functional. Oh, pick a ac switch with a equal amp capacity as the supply demands.
Old 09-18-2017, 07:14 AM
delawarebill's Avatar
yes what VW said
yrs ago i had the exact same problem. new switch was only found on mars and couldn't get it.. so i got a momentary toggle and rigged it up and worked great.
Old 09-20-2017, 08:47 AM
bsa_bob2's Avatar
Thank you all for the great suggestions and tips on this.post. i like the toggle switch mounted right on the handle idea .Theres a little black thing attatched to the switch itsself---- inside the handle, Don't need that aay? thanks bob s
Old 09-20-2017, 10:10 PM
Rip VW's Avatar
I think what your seeing is a button for locking the oem switch in the lock position so you don't have to constantly hold the switch on.
The Following User Says Thank You to Rip VW For This Useful Post:
Old 09-21-2017, 08:48 AM
bsa_bob2's Avatar
This a coil or something..The brown paper cover hides something .for safety i guess. I can make toggle work, IF i need to remove the piece in the brown wrap.Can i just hook up the switch.directly into this toggle ,eliminating that thing all together or can/' or will i burn something in the motor?
As usuall any help is really great thanks bob s
Name:	PORTABAND SWITCH 003.jpg
ID:	378297   Click image for larger version
Name:	PORTABAND SWITCH 001.jpg
Old 09-22-2017, 07:30 AM
bsa_bob2's Avatar
btt btt btt
Old 09-22-2017, 12:41 PM
bsa_bob2's Avatar
Any help is really great- thanks bob s
Inside this small brown paper wrappers is A plastic box -that have the same wires running into it and back out of it.Is it necessary? bob s
Old 09-23-2017, 09:23 AM
bsa_bob2's Avatar
btt bt btt
Old 09-23-2017, 12:33 PM
36 sedan's Avatar
Those are your switch terminals. Most power tools like this switch both the hot and neutral wires. A Double Pole Single Throw momentary switch will work for if wired through on both sides, just don't confuse the active switch terminal or you'll have a short when the toggle is turned on. Of course a simpler and easier fix would be to find a generic switch that fits your saw. Try this link and compare measurements and current ratings to match what you have.
POWER TOOL SWITCH 8307K1 with lock
Old 10-01-2017, 02:36 PM
bsa_bob2's Avatar
36 sedan. I ordered this switch . 2 days past i put it in my Portaband -it failed. do to me not having instructions. I thought i burned it up when the breaker sparked and blew.Would not run- then I emailed "Eurton Electric" and said the switch was not any good. I was very dissatisfied with it. So the owner sent me an email back---- on what to do with the switch wiring, He says the switch is ok.I did what he said; -putting my Portaband back together, after i religated -not caring - to the back room. So i pulled the switch/on My old-on portaband ---rewired it, Works great !!and you saved me from throwing out $300.00 on a new one. Was so happy i showed my wife how well it worked. ...Wonderful You never told me Robert someone gave you that saw. Very happy great week ahead. Thank you for your help
36
bob s
The Following 2 Users Say Thank You to bsa_bob2 For This Useful Post:
36 sedan (10-01-2017), Rip VW (10-01-2017)
Old 10-01-2017, 03:19 PM
36 sedan's Avatar
Glad I was able to help
The Following User Says Thank You to 36 sedan For This Useful Post:
bsa_bob2 (10-01-2017)
GM column ignition switch to dash switch Duane in Bakersfield Electrical 8 05-06-2017 08:51 PM
Trans brake switch showing small voltage, is switch bad? pdmracing Transmission - Rearend 1 09-26-2011 07:50 PM
toggle switch / ignition switch help help! 39chevy Electrical 4 08-18-2006 06:04 PM
door switch and brake switch 49dream Electrical 5 02-11-2005 10:58 PM
DIY Shiftlight/ RPM Switch/ RPM Window Switch Junorr Electrical 2 09-07-2004 07:18 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
