Low Buck Plasma Cutters - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2019, 02:29 PM
chasracer's Avatar
True Hotrodder
I recently picked up one of these low dollar plasma cutters and just had a chance today to try it out. It's a variable from about 15 amp to 50 amp and I cut some 1/8" frame material out to enlarge a hole using about 40 amp. What I don't know and the instructions are basically useless is how much air pressure should I be using? I did that cut and played around with it a bit more on some scrap that was thicker and it had no problem going right through it. But afterwards I was wondering if I should back off the air pressure or not. I made these cuts at about 135 PSI. Anyone have any idea?
Old 10-12-2019, 07:48 PM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
plasma air pressure
most plasma cutters work at under 90 PSI BUT your air needs to be dry/ a little bit of moisture can blow $ 100 in parts in a second. ask how I know. the type you will need depends on your climate and if your air compressor has a water separator. the disposable cartridges used for paint guns work for me. .
Old 10-12-2019, 08:24 PM
chasracer's Avatar
True Hotrodder
Okay, thanks for that information.
I have a separate air line that is setup differently for my spray painting work. I will start using that going forward.
Old 10-14-2019, 06:00 AM
bsa_bob2's Avatar
yup!what!! he said timothale had mine for 30 years,adjust the knobs heat range and wire speed- slowly- and try weld.....You will get excatly what you need with patience and time hth bob s
Old 10-14-2019, 06:38 AM
chasracer's Avatar
True Hotrodder
Ha-HA!!
I think you're talking about a Mig welder which I have actually become pretty good with but I would like to get better.
Thanks tho....
Old 10-14-2019, 07:13 AM
Wiki Edits: 27
before plasma
I have an old air arc cutter, it uses an ac welder, a carbon rod and blows air to burn a big nasty kerf. sometimes when I am out of acety or oxy. and just cutting scrap to go in to recycle I dip 6011 rod in a bucket of water turn up the amps on AC setting and burn away,
The Following User Says Thank You to timothale For This Useful Post:
chasracer (10-14-2019)
