Lower shock mounts on Ford 9 inch - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2018, 07:31 AM
Name:	crack in lower rear shock mount.jpg
I'm wondering why I got this crack? I had the shocks attached at the top holes on the mount to try to get the body a little higher. Maybe too much stress on the mount? I lowered the shocks to the lowest hole now. I'll have to weld this I guess. Anyone have this happen?
Old 11-12-2018, 07:46 AM
delawarebill's Avatar
shock mount
if u tried to raise the car by moving shock bottom to the highest position most likely the shock bottomed out. i'm hoping u used another way to raise the body and not thinking the shock would do it.. it wouldn't
Old 11-12-2018, 04:02 PM
ericnova72's Avatar
More for Less Racer
Shock mounts and shocks are not meant to hold the car up....that is the job of spring perches and springs.
Air shocks, and ersatz coil spring over shock combos are sold, but they are never the proper way to do things, they are just a cheat hack for someone who doesn't want to do it the right way.
It cracked because you subjected it to a load it was never designed to carry, and may have caused the shock to compress solid, which would really hit the shock mount hard.
Old 11-14-2018, 07:38 AM
PHWOARchild's Avatar
That sharp corner at the notch is why it cracked, a huge no-no when building something structural.
62 Impala:Lower shock mount, REAR control arm bolt removal. lennyjay Suspension - Brakes - Steering 2 06-01-2013 02:18 PM
Lower from Shock stud 1940 Ford Coupe artistsport3 Suspension - Brakes - Steering 4 11-27-2012 06:30 PM
How much lower will the frame lower once the real motor is installed ? Tonythefish Suspension - Brakes - Steering 3 02-05-2007 04:14 PM
shock mounts out of alignment and shock length? pcoghlan Suspension - Brakes - Steering 4 05-08-2006 06:22 AM
1979 chevy k10 lower front shock mount hiball Suspension - Brakes - Steering 2 12-17-2005 08:52 PM
