Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Main and rod bearing clearances
Old 07-11-2019, 06:40 AM
Itsjust a 305 Itsjust a 305 is offline
Look for somw help again it seems like my bearing clearances seem a lil tight. My main are betwwen .0015 and .002. I have not checks rods yet bc i ran out of time last night. Was wonding about if this was ok or if i need to get a set of that has the +.001 . my crank is .010 on both mains and rods.
Note this is what i would call a hot street motor and the plans are to u a 100-150 shot as a o **** button at the track when running heads up.
Motor specs are
Copy victor jr intake
Worked over 210cc intake procomp heads
3.5dome pistons at 4.04
3.5 stroke crank thats has a .002 gram bal
Came is 243 int./249 exh at 50 with a .600 int and exh on a 112 lob
Running a .040 head gasket
