Major shake at low speed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2019, 01:09 PM
I have a 23 t bucket, 350, powerglide, 57 rear end. Car runs fine. Problem is when I put a passenger in it with me it shakes so bad at low speed you would think i was driving over a speed bump. Person gets out and its fine. There are no leaks or squeaks or sounds when I drive it. I put it up on Jack stands and there is nothing that seems loose. Any ideas? I'm at my wits end.
Old 09-12-2019, 01:48 PM
39 master's Avatar
My thinking goes like: What changes when a second person gets in? Maybe the body squats a bit and the drive train gets out of align. Most likely your driveshaft is VERY short so any change could cause this. First I would remove the driveshaft and check the U joints to ensure they are working properly, then check the trans/rear end for proper alignment. Sand bag to add about 300+ lbs and check it again.
The Following User Says Thank You to 39 master For This Useful Post:
Gbstrike (09-12-2019)
Old 09-12-2019, 01:50 PM
could a shock be bottoming out?
The Following User Says Thank You to lmsport For This Useful Post:
fiftyv8 (09-18-2019)
Old 09-12-2019, 05:08 PM
Thanks, it makes sense, it is very short, I will load it up.
Old 09-12-2019, 05:47 PM
A flat spot on a tire or a separated belt can cause similar issues with weight or speed changes.
Old 09-12-2019, 07:27 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Makes perfect sense to me.........
Old 09-13-2019, 12:19 AM
X3, this sounds like a drive shaft angle problem at the U-joints.
Bogie
Old 09-13-2019, 05:03 AM
55 Tony's Avatar
Two different thoughts on this depending on your actual symptoms.
Does it shake along with the speed, or does it shake with road surface.
Speed - driveshaft
Road surface - shock or something suspension bottoming out
Young enough to learn ... too old to remember.
The Following User Says Thank You to 55 Tony For This Useful Post:
Old 09-13-2019, 07:28 AM
chasracer's Avatar
True Hotrodder
Like mentioned above, I believe it is a pinion angle issue or a driveshaft phasing one. I would check the angle unloaded, then put weight in the driver's seat and check it again, then add the passenger weight for a third check. My guess is that the deflection of the rear springs is changing the angle.
Here's a good site with information that might help you:
https://www.drivetrain.com/parts-cat...asing-problems
Old 09-13-2019, 08:26 AM
Little short driveshafts don't usually vibrate the car at low speed unless out by a lot, just adding a little weight seems unlikely to cause such a dramatic change.
Driveline vibrations typically have a harmonic frequency to them, at some MPH they create a cyclical vibration that typically goes away as speed increases, and then comes back at 2X the original MPH with a frequency that is double but a small amplitude.
Old 09-13-2019, 03:53 PM
39 master's Avatar
By the way, can you tell us what rear suspension you have? Coil spring, coilovers or transverse spring.
