Making Oval Holes In Fiberglass Fenders - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2016, 06:05 PM
I'm in the process of installing after-market '39 Ford tail-lights in Wescott fiberglass fenders. The mounting stud holes are drilled, plus I've used a hole saw to to cut out the upper section of the oval tail-light housing. I'm now to the point where I need to expand the hole to the required oval shape.
Question: Should I use a Dremel burr to expand the cutout to the required shape, or would a jig-saw be a better tool? Also, any other tool suggestions?
Thanks for all input......
Old 09-30-2016, 10:33 PM
idrivejunk's Avatar
Grand Prix user
Last journal entry: Last look
I'd use the burr just for better control of the very final trimming. But I'd want the 1/4" kind of burr bit rather thatn 1/8". The Dremel drums would work pretty good, I think.
Old 10-01-2016, 01:31 PM
A file and doing it by hand works real well, doesn't take too long, and less chance of "Dang It!".
Old 10-01-2016, 01:42 PM
raidmagic's Avatar
Last journal entry: Studebaker
An air saw would work and the blades are really fine so you have good control
The Following User Says Thank You to raidmagic For This Useful Post:
crdnblu (10-01-2016)
Old 10-01-2016, 01:57 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
I have used a wood rasp to good advantage to finish fiberglas before.
https://jet.com/product/detail/96ac7...EH0A&gclsrc=ds
Old 10-01-2016, 01:58 PM
Yep; the air saw would probably give me the most control, but, unfortunately, I have no compressor in my home shop.
Thanks for all your input; I'll probably give the burr a shot, with a file for fine-tuning.
Old 10-01-2016, 07:32 PM
Cape Cod Bob's Avatar
Last wiki edit: How to title a hot rod
By hand for sure or a cylindrcal sanding tool in a drill. DO NOT use a jig-saw, you risk cracking the glass, especially if it is old.
Old 10-03-2016, 11:43 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
A round file called a rat tail file. For bigger holes dremel has a rotory cutting tool ,it looks like a drill bit but it cuts sideways or even a trim router for trimming counter tops.
Making square holes EZ deadbodyman Body - Exterior 4 11-06-2015 05:21 AM
making custom oval exhaust. muffler help please. AndersonRacing44 Engine 6 12-04-2010 08:56 PM
Fiberglass inner fenders? DB66elky Body - Exterior 1 03-16-2010 06:28 PM
Fiberglass Fenders 37fordpickup Body - Exterior 12 11-14-2006 06:05 PM
Fiberglass fenders jcclark Body - Exterior 4 06-16-2005 06:25 PM
