masking weather strip - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2017, 12:32 PM
mustangboss's Avatar
Does anyone have any tricks to get the tape 3m 233 to stick to rubber.We used to use some stuff called tape-it but no longer avail. Thanks
Old 02-02-2017, 10:19 PM
Cleaning it with lacquer thinner should help But honestly, I find it hard to even think about masking it, I remove it.
Old 02-03-2017, 08:17 AM
yep r&i but this rubber in made out of unabtainium ,so was lookn at other options
Old 02-03-2017, 08:51 PM
Ahhhhh, yeah cleaning it has worked the best for me. But you have to be VERY CAREFUL as to not make the tape stick too good! You could damage the rubber removing it.
Old 02-05-2017, 05:14 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
LOL, I just cant believe all the crap people can come with to sell people. All you need is wax and grease remover, Thats it. W&G the rubber at least once before you tape the car, then once when you do the whole car.
Remember to "wax on wax off" and your all set, the reason lacquer thinner wont work is, for one its to aggressive and can melt some materials and TWO it evaporates to fast to "wax off" while wet. Any W&G remover will work. for plastics and rubbers
Old 02-05-2017, 10:22 AM
You are very right DBM, the wax and grease remover is where you want to start at the very least. Using it properly as you laid out should do the job. Unless there is something like Armorall (DAMN I HATE THAT STUFF) on it the wax and grease remover should work.
Old 02-05-2017, 04:23 PM
One more thought is after the W&G remover, a coat of hairspray. Then the tape should stick just fine, and the rubber won't be damaged. If it's not all hard and brittle, mabe pull back tape would work.
Old 02-09-2017, 07:04 AM
Wiki Edits: 11
A second wipe down may be required and on some car that are heavily dosed in afro sheen a third go, if that don't do the trick remove the weather strip and tape to the pinch weld. I had one that was a real problem it looked like it was dipped in the crap. If you remove the weather strip, wash your hands right away or everything you touch will be contaminated.
Roof Rail weather strip camaro 67 Body - Exterior 0 11-17-2014 08:09 PM
new weather strip for 77 f150 rxlmod Interior 1 04-22-2010 07:50 PM
weather strip sealer oldred Body - Exterior 0 07-23-2008 02:05 PM
question on tape to weather strip? FRANKBULLITT Body - Exterior 2 01-15-2008 04:50 PM
Weather Strip Guy Hiltz Body - Exterior 2 12-19-2005 07:12 AM
