Master cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2019, 08:33 PM
Master cylinder
Can you use a master cylinder from a 98 s10 pickup on a hot rod?
Old 03-07-2019, 11:31 PM
ericnova72's Avatar
More for Less Racer
Sure, I'm using one on a '72 Vega converted to V8 right now. Uses the S-10 front disc/spindle conversion along with 10.5" rear drums.
The Following User Says Thank You to ericnova72 For This Useful Post:
35chevyjim (03-08-2019)
Old 03-08-2019, 07:26 AM
Old(s) Fart
Last wiki edit: Wheelbase database
The brakes neither know nor care where the M/C came from. The only things that matter are bore, piston stroke, whether or not the M/C has residual pressure valves in the outlet ports, and the needs of the wheel cylinders. Without knowing more about your system, it is impossible to tell if the S10 master is correct.
The Following User Says Thank You to joe_padavano For This Useful Post:
Master Cylinder Bore size, what size is this? bubbahotep Suspension - Brakes - Steering 3 04-22-2013 05:26 AM
Clutch master cylinder G-Body T5 swap greenmoonshine Transmission - Rearend 4 05-07-2010 06:37 PM
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
