Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Master Cylinder Bore Difference
Old 04-20-2019, 11:40 PM
enjenjo enjenjo is offline
A 7" booster does not give you much boost, there is just not enough area on the diaphram. Now if you use a 7" dual diaphram you double the boost, and in most cases the booster is all you have to change.
A 1" bore master cylinder will make more pressure for the same foot force than a 1 1/8" bore master cylinder, but has a bit more travel doing it.
The Following User Says Thank You to enjenjo For This Useful Post:
tools (04-23-2019)
