Metal Reinforcing in a glass body - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2008, 07:54 PM
I need some pictures of an inner metal floor reinforcing for a fiberglass closed Model A Ford, any help? I am currently building a glass 30 Ford pickup and I not satisfied with the way I made it….Why a glass body? Because in Brazil this little beauties are not easy to find….
Name:	30 glass body.JPG
Old 05-16-2008, 08:19 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I am building a 32 truck, it is steel but I did the floor in sheet metal on top of a small frame made of 1x2 square tubing. I am not sure what you would like to know and a picture of your current floor would answer so many questions.
That might generate some fresh ideas from us viewers
see if this helps in any way https://www.hotrodders.com/gallery/sh...cat/500/page/3
Old 05-17-2008, 07:26 AM
powerrodsmike's Avatar
Wiki Edits: 161
Here is a recent thread that has some good links to pictures of steel reinforcing installed in bodies, , and a good discussion about steel reinforcing.
https://www.hotrodders.com/forum/help...dy-137358.html
Please read down a few posts,(starts at post 7), in that thread and then be sure to click on the links to wescotts.
Here is the link anyway.
http://www.wescottsauto.com/body-steel/p-steel-1.htm
Hope this helps,
Mikey
BE different....ACT normal.
Old 05-19-2008, 09:09 PM
Could I ask...
Mikey:
Could I ask you a question? PoliForm makes Ford Model A five windows. Do you remember how they manage the floor? I attached a figure showing how I think the inner structure should be. If I am using a 32 like chassis, I need just a plate of steel because the chassis surrounds the body , but a Model A chassis has the rails in a inner position. In this case I need to use some structural shaped metal to build my body sub frame. Does it should be “U” shaped? Up or down? Any help /idea will be usefull…
Aurelio
Old 05-19-2008, 11:12 PM
Wiki Edits: 161
Poli-Form only built model A roadsters, not closed cars, ( 'cept the 34 coupe). Wescotts builds a 5 window, IIRC.
The steel in the floor was 1/8" x 1 1/2" flat bar, edge bent to lay over the body mounting holes at the cowl, door front door rear , and at the tab on the frame at the back of the body.
You could put some 3/4" x 1 1/2 rectangular tubing in the channels that are in the floor, if it is molded like the original.
That would give you a place to bolt a seat rail, if you are not using a seat tray like the stocker. They'd also be a good place to bolt some seatbelts.
Later, mikey
Old 05-20-2008, 04:28 PM
thickness
Do you remember the thickness of the glass floor?
Sprayable Body Filler robs ss Body - Exterior 10 11-19-2007 06:56 PM
Alternative Metal Body Filler bg Body - Exterior 3 06-14-2006 02:56 PM
glass cutting sbf342 Body - Exterior 8 10-04-2005 08:41 PM
All Metal body filler Tedly Body - Exterior 6 06-03-2003 03:02 AM
GLASS BODY UPDATE!! bomo Body - Exterior 2 07-02-2002 05:26 PM
