Minimum distance between exhaust and braided stainless fuel line - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2019, 12:38 PM
Is there a rule of thumb minimum distance between exhaust and braided steel fuel line? About 10 after my driver side header collector my fuel feed and return lines cross over the exhaust system, they dont run the length of the exhaust, they just cross over in one spot. There will be about 3-3.5 inches of clearance between the pipe and hoses, I have a Velcro type heat barrier to put around the hoses plus there is a factory aluminum shield that will be under them. I feel this should be a non issue just curious if there is a minimum safe distance. Thanks.
Old 02-27-2019, 01:16 PM
silver74vette's Avatar
That does not sound like an issue to me as long as they are supported, Especially if you have radiant heat insulation installed.
Old 02-27-2019, 01:57 PM
https://www.ebay.com/itm/Red-3-feet-...naW8:rk:2:pf:0
Click on above. I've used this stuff and it works great.
Old 02-27-2019, 03:41 PM
Heat soak might be a problem on hot shutdown
Old 02-27-2019, 03:44 PM
Thanks guys, I figured itd be ok with two heat barriers, I was thinking about the hot soak temps but the truck is efi with a return system and it moves a lot of fuel so I think itll be ok
distance between exhaust and body sooper Engine 4 02-22-2010 11:31 PM
Summits 6an braided stainless line tommer2 Transmission - Rearend 3 04-24-2008 08:12 AM
Distance Between MIG Gun and Workpiece xhp734 Body - Exterior 4 01-24-2008 10:26 AM
Stainless Braided Hose Sleeving Help leejoy Engine 5 04-06-2006 12:36 PM
