Hot Rod Forum : Hotrodders Bulletin Board (https://www.hotrodders.com/forum/)
-   Suspension - Brakes - Steering (https://www.hotrodders.com/forum/suspension-brakes-steering/)
-   -   mixing LT and P rated tires? (https://www.hotrodders.com/forum/mixing-lt-p-rated-tires-384530.html)
matt167 06-24-2015 08:29 AM
on my ratrod I want the big and little stance. the calculated diameter for the rear suspension is 30" ( 10" kickup ). I know that a 31x10.5x15 would fit the bill, or a 265/75/15 would also and that's a common size in p rated due to the Z71 GM trucks. BUT, the real tall and skinny look would be a 235/85/16 and that is only available as an LT tire. I think D rated was the lowest ply rating I found and that was for Chinese tires.. The front tires are just going to be a 14" tire, around a 24-25" diamater so obviously P rated.
If I put LT's in the back and P's in the front will it cause any really bad handling characteristics or should I just deal with the wider 265? I'm looking in highway rated tires like a General Grabber HTS
chevymike 06-24-2015 03:43 PM
In your use, it won't make much difference as for handling, as you really don't have any. What you will have with a LT tire (D or E rated) is a very stiff sidewall. It will likely ride rough even at very low pressures, since you are not talking about a lot of weight on them. Ride wise, the P series will ride way better.
matt167 06-24-2015 07:11 PM
that makes sense. They are much cheaper too. I can get Dextero DH2's for $110 plus a 10% discount. There a cheaper straight highway tire but we sell a lot of them at the tire shop
delawarebill 06-25-2015 01:28 PM
mix n match of tires
no problem do it.. i had 20" wide bias on rear and 225R15 Michelin on the front of my Tbucket.
matt167 06-25-2015 02:00 PM
do you think a tire 30mm less in width will make a big enough difference in the look?
I like these Firestones Firestone Destination LE2 - Free Delivery Available | TireBuyer.com
matt167 06-28-2015 09:32 PM
I think I'm going to use the 235/85's and put them on some basic replacement 16x6.5 steel wheels that were for a 2002 Chrysler Concorde's winter tires. they were bought new and had 2 sets of tires installed, so they should clean up nice. They have been kicking around for 5 years or so. FWD wheels sure, but it does not matter since I can build the offset to work. They fit the hubs. It currently has stock Carevan wheels and tires on it as rollers which are basically the same wheel
