mixing LT and P rated tires? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2015, 08:29 AM
Wiki Edits: 31
on my ratrod I want the big and little stance. the calculated diameter for the rear suspension is 30" ( 10" kickup ). I know that a 31x10.5x15 would fit the bill, or a 265/75/15 would also and that's a common size in p rated due to the Z71 GM trucks. BUT, the real tall and skinny look would be a 235/85/16 and that is only available as an LT tire. I think D rated was the lowest ply rating I found and that was for Chinese tires.. The front tires are just going to be a 14" tire, around a 24-25" diamater so obviously P rated.
If I put LT's in the back and P's in the front will it cause any really bad handling characteristics or should I just deal with the wider 265? I'm looking in highway rated tires like a General Grabber HTS
Old 06-24-2015, 03:43 PM
chevymike's Avatar
In your use, it won't make much difference as for handling, as you really don't have any. What you will have with a LT tire (D or E rated) is a very stiff sidewall. It will likely ride rough even at very low pressures, since you are not talking about a lot of weight on them. Ride wise, the P series will ride way better.
Old 06-24-2015, 07:11 PM
Wiki Edits: 31
that makes sense. They are much cheaper too. I can get Dextero DH2's for $110 plus a 10% discount. There a cheaper straight highway tire but we sell a lot of them at the tire shop
Old 06-25-2015, 01:28 PM
delawarebill's Avatar
mix n match of tires
no problem do it.. i had 20" wide bias on rear and 225R15 Michelin on the front of my Tbucket.
Old 06-25-2015, 02:00 PM
Wiki Edits: 31
do you think a tire 30mm less in width will make a big enough difference in the look?
I like these Firestones Firestone Destination LE2 - Free Delivery Available | TireBuyer.com
Old 06-28-2015, 09:32 PM
Wiki Edits: 31
I think I'm going to use the 235/85's and put them on some basic replacement 16x6.5 steel wheels that were for a 2002 Chrysler Concorde's winter tires. they were bought new and had 2 sets of tires installed, so they should clean up nice. They have been kicking around for 5 years or so. FWD wheels sure, but it does not matter since I can build the offset to work. They fit the hubs. It currently has stock Carevan wheels and tires on it as rollers which are basically the same wheel
Ever seen one of these?? (Rated G) wretched ratchet Off-Topic 12 03-28-2008 12:06 AM
Speed Rated Tires Dreadlord General Rodding Tech 2 02-23-2004 01:25 AM
Speed rated tires Dreadlord General Rodding Tech 1 12-23-2003 10:12 PM
