Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - MOTOR MOUNTS (Engine Mounts)
Old 08-28-2009, 09:52 AM
PackMule PackMule is offline
Last journal entry: Done with the Engine
Thank You For Your Reply!... I Bought Thoes Mounts. But "see the 3 Studs Shown in the pic?" There are metal connecting brackets to them; that bolt to the block. they must be different between the 2.3 & 1.8.
I Saw an '85 Courier, in Pick your Part: But, the mounts were totaly different. I would need to cut the entire motor mount system from the frame, of mine & the one in the salvage yard, than weld the new ones in; to swap.
I have the truck ready to put engine and trans in; than design motor mounts needed. (unless, I find the brackets for the 2.3 for thoes motor mounts.) Engine & Trans are 24" longer; so the rear mount will be fabed too.
