Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mounting v6 4.3L on impala 77 l6 250
Old 08-30-2019, 06:24 PM
55_327's Avatar
55_327 55_327 is offline
Originally Posted by d.b. cooper View Post
The trans can stay in the same place----no need for a new crossmember.
FWIW, when I replaced the 250 six with a 350 in my 82 C10, I needed new "clam shells" (the brackets that mount to the engine). Also had to relocate the frame brackets to another set of pre-drilled holes on the crossmember.
Keep in mind there are several different models of clam shells, each with a different engine mounting height.
The Following User Says Thank You to 55_327 For This Useful Post:
Husein-p (08-31-2019)
