Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mounting v6 4.3L on impala 77 l6 250
Old 09-01-2019, 02:20 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Last wiki edit: DynoSim combinations
Wiki Edits: 326
[QUOTE=Husein-p;4692413
stock piston can be use again after rebuilding engine ?
this v6 is std but need to shave to about 20 or 30 pistons if i use stock v8 350 piston but healthy pistons is ok or not ? tnx [/QUOTE]
Yes, the V6 uses the same piston as the V8. Check piston to valve clearance if you use a hot rod cam.
The Following User Says Thank You to techinspector1 For This Useful Post:
Husein-p (09-21-2019)
