Muncie m20 vs M21 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
  #16 (permalink)
Old 09-08-2014, 07:38 PM
Last journal entry: 1979 Camaro Berlinetta
I want a t-10 but they are a lot of money plus I can get my friends rebuilt muncie m21 for $500 and I'm told it bolts right up and I can use the same spedo cable.
Quick reply to this message
  #17 (permalink)
Old 09-09-2014, 02:13 AM
BuzzLOL's Avatar
Cars, Trucks, Boats
Originally Posted by 79CamaroMatt View Post
I was stating that mine was a rpo code m20 saginaw used in my 79 camaro, I was seeing what a muncie m20 or m21 would do
. If the Muncie and Saginaw have the same gear ratios, you won't be able to tell any difference driving them... GM just used Saginaws on engines under 327" and Muncies on larger engines...
. Close ratio trannies are used with big rear end gears, because a big 1st gear is overkill and becomes a 'granny' gear then... also, close ratios have less RPMs drop between gears, so better for racing....
  #18 (permalink)
Old 09-09-2014, 06:08 AM
big gear head's Avatar
High Performance Rear Ends
The Muncie transmissions had the speedometer cable on either side. I've got 3 with the cable on the left and 2 with the cable on the right. I've got a ST10 from a Z28 with the cable on the right.
$500 for a good Muncie seems like a pretty good price. If you were close I'd fix you up with a complete ST10, shifter and drive shaft.
  #19 (permalink)
Old 09-09-2014, 11:58 AM
How much I'm in lima ohio
  #20 (permalink)
Old 09-09-2014, 01:48 PM
BuzzLOL's Avatar
Cars, Trucks, Boats
. I think there's others on here from Lima... (or Leema as they pronounce it in Thomas Crown Affair movie)
  #21 (permalink)
Old 09-09-2014, 03:46 PM
That's a long way up there. I priced everything with the bell housing, clutch, shifter, drive shaft to a local guy for $750. He wants me to put it in a Monte Carlo, but I don't want to do it. This came out of a Z28.
  #22 (permalink)
Old 09-09-2014, 05:50 PM
$750? Shoot I'd get that.
  #23 (permalink)
Old 09-09-2014, 06:37 PM
I'm not selling it to him if I can keep from it. I don't want to deal with changing the Monte over to a manual transmission. If I can sell it before he comes up with the money then I don't have to do it.
Closed Thread
camaro, chevy, muncie, transmission
M20 Muncie Shifter 04silvyhotrod Transmission - Rearend 5 05-14-2014 02:22 PM
M20/M21/M22 Parts Diagram and Assembly AutoGear Transmission - Rearend 4 08-17-2010 05:33 PM
muncie m20 350sblock Transmission - Rearend 5 05-08-2008 02:40 AM
What's The difference between an M20 and a M21 JimKramer Transmission - Rearend 5 02-16-2006 07:43 AM
trying to decode my muncie M20 TCAMARO Transmission - Rearend 1 05-12-2005 04:55 PM
