mustang 2 lower control arms - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2018, 02:31 PM
Been awhile since posting--need some advice or help--have 48 Chevy 2 door sedan with true Mustang 2 front end---not sure of what year. The person who built it widened it 2 inches--fits real nice in the wheel wells. one of the problems I am having it denting the front shocks--have gone to a skinnier cylinder and has helped some---but PO welded a plate on the bottom of the lower control arm and cut a large hole and installed Monte carlo shocks--which I have replaced twice in 3 years---also drilled an extra hole in the frame where the rack mounts---had to gusset both the hole for added support. I am wanting to know if anyone on the site has done this, seen this done and if I can install stock lower control arms and then install the Mustang 2 shocks. may or may not help in quality of ride-- Car has around 34k on it so it has been driven. Thanks in advance
ID:	435399   Click image for larger version
ID:	435401   Click image for larger version
ID:	435403   Click image for larger version
ID:	435405   Click image for larger version
The Following User Says Thank You to reborn55 For This Useful Post:
skip99 (02-05-2020)
Old 09-19-2018, 09:32 AM
kso's Avatar
kso kso is offline
Gosh, why can't anyone weld? It's so easy.
I gather the stock crossmember has had a splice welded in the middle of it to widen that, then holes for the Mustang II rack (?) were re-drilled to center it and you've had to sleeve those. I'd imagine the guy who added the plate to the control arms for the different shocks (see welding comment above) just put the shock in a location where it hits stuff and that needs to be moved, or removed to go back to the stock Mustang II parts which seems to work for most people. What's being used for a bump stop now, by-the-way, with the shock change? A front-on photo with all assembled and at ride height would be most helpful.
Old 09-19-2018, 09:33 AM
454 Rattler's Avatar
NEVER SATISFIED !!
Someone should jump in pretty soon. I'm looking forward to hear what they have to say. I think everyone with the old MII setup would like to have a better ride on their street rod.
KSO must have been typing while I was replying.
454 RATTLER
Old 09-19-2018, 09:44 AM
kso's Avatar
kso kso is offline
My --feeling-- from over time is that most people who have a bad time with the MII's have situation where it is not being operated within it's original design parameters (mostly ride height), or does not have the spring or shock rate dialed in to the weight of the car, or could use a little more caster 'cause of being on a light car with modern tires. They'll never be a great suspension but they should do OK. This widened unit will be flirting with having a little bumpsteer if being used with the stock rack but if at level height that will probably never be a problem.
Old 09-19-2018, 10:33 AM
Thanks all--kso you hit the nail on the head in regards to way it is set up---have 2 pics her I took last year---will get more as soon as rain stops to show if it helps---so I can probably go and replace lower arms and use stock shocks with out any problem--has a little bumpsteer any way to alleviate it
Name:	mustang 1 1.jpg
ID:	435439   Click image for larger version
Old 09-19-2018, 11:01 AM
FASTFORD's Avatar
I am just throwing thoughts out here,
1st, your 48 is around 3100 lbs and a Mustang 2 was 1600 lbs.
the original had strut rods designed into the front end and with the heavier car you may need the strut rod to keep movement to a minimum.
2nd, it could be the PO installed that plate in the wrong position
so when the suspension is working the shock gets pinched/dented.
you would need to simulate suspension travel to see exactly where/how the shock is getting hit to determine the best location
for the mounting plate.
hope this helps.................
Old 09-19-2018, 11:21 AM
Thanks--I do have strut rods on the car---the shock actually is making contact and getting dented on the opening hole where the spring sits--where the original shocks would be placed---thanks again
Old 09-19-2018, 01:50 PM
kso's Avatar
kso kso is offline
MII's were around 3,000 lbs and close to most street rods, part of why it works well. Pintos were in the low 2's, with parts used on drag cars more.
Random discussion re: weight https://www.stangnet.com/mustang-for...ang-ii.787074/
Old 09-19-2018, 02:40 PM
FASTFORD's Avatar
yep, my bad........
curb weight was 2867 per the Ford release in 1974
1974 Ford (USA) Mustang II Base 3-Door 2+2 full range specs
Old 09-19-2018, 03:20 PM
thanks again--my car is around 3500 curb weight
903 lf 848 fr
865 lr 884 rr
some pictures taken today have been added--one pic if off due to camera angle
ID:	435451   Click image for larger version
ID:	435453   Click image for larger version
ID:	435455   Click image for larger version
Old 09-21-2018, 04:30 PM
I tried to explain the bump steer on the other board. The tie rod on the right is 2" longer than the one on the left, so you need a 2" rack spacer on the right to make both tie rods the same length. They are easy to install.
Old 09-21-2018, 04:54 PM
ericnova72's Avatar
More for Less Racer
yep, my bad........
V8 Cobra and King Cobra models with an automatic trans went close to 3100 lbs, if not a little more....it was a rather porky little car!
Friend of mine in High School had a V8/Automatic Ghia Coupe, it was 3040 lbs all stock on the local agricultural scale. He couldn't believe that little car was that heavy. Lots of dead weight behind the bumper covers in those 5 mph impact bumpers.
Old 09-21-2018, 05:43 PM
Posted this on the other board
Ok now I am confused--when I got the car it had the shorter tie rod ends---from working on a 36 chevy with short tie rods and no turning radius among other things we installed the longer ones---on the 48 I have replaced both tie rod ends with the longer tie rod ends--so I really don't see where the lextension would fit with my setup--correct me if I am wrong---there is very little differnece in length on each side--may look that way in the picture but not really---have equal turns frome center to each side--clearance full lock is same on each side---if I need teh reack extender I will get but--THANKS
LOWER CONTROL ARMS. PLEASE HELP Pro1972nova Suspension - Brakes - Steering 4 03-01-2012 09:19 PM
Stock Mustang II Lower control arms on a '56 f100.. Hwyhogg Suspension - Brakes - Steering 9 12-22-2011 05:35 AM
Narrowed upper & lower control arms Michael Bean Suspension - Brakes - Steering 1 12-29-2002 03:40 PM
Nova Lower Control Arms Pro1972nova Suspension - Brakes - Steering 1 12-15-2002 01:26 PM
rear lower control arms oldsnut Suspension - Brakes - Steering 3 12-15-2001 09:01 AM
