Mustang 2 rack adjustment ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2019, 05:05 AM
My 31 Ford has a new Mustang 2 rack and pinion from Heidts and being a newby I was wondering if the toe adjustment is just done with the outer tie rods or can the inner ones also adjust ? I get close just using the outer but moving it one turn seems to over adjust. Im trying to get it close until I can get it to a shop for a real alignment.
Old 09-08-2019, 08:29 AM
39 master's Avatar
As far as I know there is no adjustable inner tie rods on a rack and pinion. Toe is adjusted with the (outer) tie rods. The shaft coming out of the rack has a ball and socket so the arm will move up, down and back and forth with the wheel.
The Following User Says Thank You to 39 master For This Useful Post:
Skooch62 (09-08-2019)
Old 09-09-2019, 04:56 AM
Bob37pont's Avatar
Curmudgeon at Large
The inner tie rods will spin on that ball & socket to allow more precise afjustment of the threads on the outer. You don't have to turn the outer a full rotation.
The Following User Says Thank You to Bob37pont For This Useful Post:
Skooch62 (09-09-2019)
