Hot Rod Forum : Hotrodders Bulletin Board (https://www.hotrodders.com/forum/)
-   Suspension - Brakes - Steering (https://www.hotrodders.com/forum/suspension-brakes-steering/)
-   -   Mustang ll upper control arm bushing squeak (https://www.hotrodders.com/forum/mustang-ll-upper-control-arm-bushing-squeak-521449.html)
lt1tyrell 06-05-2019 08:09 AM
What is the best lubricant to get rid of a squeak in these heidts control arms? They are the rubber bushings, I tightened the cross shaft nuts with the weight on the car and have tried using some white lithium grease with no luck. Anybody tried graphite lubricant? If I back off the cross shaft nuts and go around the block they are silent. Thanks
39 master 06-05-2019 08:20 AM
While on a trip last year my sway bar bushings and rear 4 bar bushings started to squeak and I sprayed WD40 on them as a quick fix and they have not peeped since. Fully intended to use some silicone spray but see no need now.
