MustangII Front end problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2015, 09:33 AM
Have a 33 Ford with MII front end. Put new calipers, pads, and master cylinder and bled all lines. When you apply brakes, the front calipers on both sides will not release until vehicle sits for awhile and then they release and you have to pump the pedal to get pressure and they freeze again! Could it be a bad proportioning valve? Any assistance would be appreciated!!
Old 07-31-2015, 10:13 AM
33Willys77's Avatar
make sure you rod going into the master is not too tight - may not be releasing all the way. Could have dirt in the line - plugging a passage back into the master or proportioning valve. Pumping to get pressure means there is air in the line.
The Following User Says Thank You to 33Willys77 For This Useful Post:
kipton66rodder (07-31-2015)
67 C-10 with some front end problems stempy4930 Suspension - Brakes - Steering 7 10-01-2012 10:17 AM
T-350 Front end play problems bigorangechevy Transmission - Rearend 11 06-02-2011 03:41 PM
1933 Chevy front end problems Tubbed71 Suspension - Brakes - Steering 11 08-23-2009 05:22 PM
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 07:03 PM
front end problems tonylsg Suspension - Brakes - Steering 13 04-15-2003 06:47 PM
