My bad with my ignition switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2018, 11:58 PM
I have a 58 Chevy Apache stepside that I had to take the ignition switch out of in order to get a key made for it because the key was lost years ago but In my rush I forgot to mark the wires and where they go should I just trace the wires or do any of you know how it connects? Thank you for your help.
Old 07-02-2018, 12:42 AM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Wait for your service manual.
Old 07-03-2018, 09:01 AM
PHWOARchild's Avatar
What is there, like 4 to 6 connections on it? Most older ones have accessory, start (solenoid), battery and ignition.
Possible wire colors:
Acc = Brown
Start = Purple
Battery = Red
Ignition = Pink
Some newer switches may have 2 battery terminals (1 always hot) and 2 ignition terminals.
Old 07-03-2018, 11:54 AM
ogre's Avatar
the 'Duracell Project'
unless your truck was a v8 version and the vin starts with a V, it had a floor starter
pretty basic connections with no start and no accessory function, more or less on/off, only 3 terminals: batt, ign1, ign2
the v8 version added the turn to start and solenoid teminal
using a stock replacement harness and no accessories? then reuse the ignition switch
if you are using an aftermarket harness you'd be better off with an aftermarket ignition switch, as the stock switch won't handle much load
no fuse box in a stock truck either. not until you got the deluxe upgrades: heater, radio and electric wipers
i believe the wiper upgrade got the 4 fuse panel, if you only had the radio and heater it had inline fuses
all light overload protection was in the headlight switch with one small fuse on top for dash lights
head, tail, stop protection was bimetal strips on the headlight switch
Old 07-03-2018, 11:55 AM
ogre's Avatar
go here The 1947 - 1959 Chevrolet & GMC Pickups Message Board - The 1947 - Present Chevrolet & GMC Truck Message Board Network
Old 07-03-2018, 08:57 PM
Thank you guys for your help. I found a wiring diagram that matches up with what was said in the post above so on the fourth I should be able to get it done and started.... I’ll keep y’all posted.
GM column ignition switch to dash switch Duane in Bakersfield Electrical 8 05-06-2017 09:51 PM
Trans brake switch showing small voltage, is switch bad? pdmracing Transmission - Rearend 1 09-26-2011 08:50 PM
toggle switch / ignition switch help help! 39chevy Electrical 4 08-18-2006 07:04 PM
Bad Ignition Switch Test street rodder 1937 Electrical 5 02-22-2006 10:50 AM
bad Ignition switch??? Big86inthestixx Electrical 3 12-05-2003 05:39 PM
