My first s15 v8 swap...driveshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2011, 04:59 PM
mean s15
s15 v8 swap
I'm also doing my s15 v8 swap. I'm using 350 Chevy 350 trans, Its a long box so I'm not really sure of the factory drive shaft. Anybody?
Old 03-17-2011, 02:50 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What was in it originally?
Old 03-17-2011, 08:05 AM
bondo's Avatar
Ayuh,... So What's the Question....
Stuff the motor/ tranny in, meassure the driveshaft length needed, 'n have it built...
Old 03-17-2011, 08:57 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Moving this to the Transmission/Rearend area.
Old 03-17-2011, 03:07 PM
mean s15
driveshaft
Motor and trans came out of 70 nova. My question was would I get by with my stock driveshaft for now? I guess your right need to measure
Old 03-17-2011, 03:41 PM
Wiki Edits: 49
Guaranteed the driveshaft won't be the same length as the stock one. They never are. Any good driveline shop should be able to build you a driveshaft (once you have the measurements) for about $150.
Centerline
HotRodsAndHemis.com
"My next door neighbor just had a pacemaker installed. They're still working the bugs out, though. Every time he makes love, my garage door opens." - Bob Hope
Old 03-17-2011, 06:08 PM
mean s15
driveshaft
That's what I figured. It's got a split shaft anyways I heard they won't hold up. Thanks guys
Old 03-17-2011, 06:31 PM
If it was originally equipped with a 700r4/2.8 v6 and you can use a 700r4 in the swap, the same crossmember and drive shaft can be used with only minor modification to the crossmember(trim the front edge for clearance and ream out the hole to allow the transmission to move rearward about 1/2 inch) if you use engine brackets that allow the engine position to be adjusted
Old 03-17-2011, 06:37 PM
mean s15
driveshaft
The truck has the 2.8 and 200c trans in it.
Old 03-17-2011, 06:47 PM
mean s15
If it did have a 700r4 I think its the 60 degree bolt pattern.
Old 03-17-2011, 06:51 PM
mean s15
driveshaft
Old 03-17-2011, 06:55 PM
SSedan64's Avatar
The TH200/200C Trans is the same length as the TH350 w/6" Tailhousing. Trans mount is also in the same location.
Old 03-17-2011, 07:28 PM
mean s15
Thats good to know. I appreciate the help on this everyone
Old 03-18-2011, 07:45 AM
You're a local guy, cool! I expect to see a V8 S15 at all the cruise nights soon
...Lets see some pics of this thing
Old 03-18-2011, 10:44 AM
mean s15
Yeah need a little bit more work but I plan to show it anyway. Theres a couple pics up so far.
