Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - My homemade brake bleeding apparatus
Old 05-27-2019, 08:57 AM
brading brading is offline
You can also use the pump sprayer system described by " jseabolt " to reverse bleed the brake system if you have trouble get the air out of the system, see "Reverse Brake Bleeding by Brooksy99 on this forum.
On the point of the Dodge Neon type sealed system be very careful to follow the correct procedure when changing the clutch. Have a similar system on my Peugeot. When we changed my clutch we did not follow the correct procedure. The release bearing is pulled backward to release the clutch and the throw out arm needs to pulled back to lock it into the release which we did not do. So when I pushed the clutch pedal down there was no pressure on the arm, the M/C piston went to the end of the M/C and stuck. It took a lot of effort to get it working properly again with out changing the complete system
