Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - My junk
Thread: My junk
Old 06-23-2019, 10:04 AM
predator carb guru's Avatar
predator carb guru predator carb guru is offline
Mark Goulette
My junk
Here's some info on my junk:
2001 Mike Bos RED. 257" car, Top dragster, double slip joint car. Engine is a 665" all aluminum BBC, 12* custom profiler heads, Brodix block, billet crank, MGP rods, Gibtec pistons, custom 55mm Comp Cams cam, ported Profiler tunnel ram. Currently being fed by two custom 1295 King Demon carbs, and a single stage of nitrous flowed and jet mapped by Robert Lane of Fast Lane Nitrous. Soon to be upgraded to alcohol with a complete new Ron's Fuel injection dual Terminator setup, using twin 2100 cfm throttle bodies. New nitrous system is from Nitrous Express, set up for alcohol as enrichment...
Trans is a JW cased power glide, 1.80 low gearset and pro tree brake. 3196 Mickey Thompson slicks on Mickey Thompson Pro 5 beadlock wheels. Converter is custom.
Engine made 1510 hp @ 7200 rpm, motor only.
ID:	444499   Click image for larger version
ID:	444501   Click image for larger version
The Following User Says Thank You to predator carb guru For This Useful Post:
Rip VW (09-29-2019)
