Hot Rod Forum : Hotrodders Bulletin Board (https://www.hotrodders.com/forum/)
-   Projects/Builds/My Ride (https://www.hotrodders.com/forum/projects-builds-my-ride/)
-   -   My junk (https://www.hotrodders.com/forum/my-junk-521687.html)
predator carb guru 06-23-2019 09:04 AM
My junk
3 Attachment(s)
Here's some info on my junk:
2001 Mike Bos RED. 257" car, Top dragster, double slip joint car. Engine is a 665" all aluminum BBC, 12* custom profiler heads, Brodix block, billet crank, MGP rods, Gibtec pistons, custom 55mm Comp Cams cam, ported Profiler tunnel ram. Currently being fed by two custom 1295 King Demon carbs, and a single stage of nitrous flowed and jet mapped by Robert Lane of Fast Lane Nitrous. Soon to be upgraded to alcohol with a complete new Ron's Fuel injection dual Terminator setup, using twin 2100 cfm throttle bodies. New nitrous system is from Nitrous Express, set up for alcohol as enrichment...
Trans is a JW cased power glide, 1.80 low gearset and pro tree brake. 3196 Mickey Thompson slicks on Mickey Thompson Pro 5 beadlock wheels. Converter is custom.
Engine made 1510 hp @ 7200 rpm, motor only.
idrivejunk 06-23-2019 09:15 AM
If you need a driver, just holler. Ha ha. Sounds fast!
predator carb guru 06-23-2019 09:26 AM
Um, no.....hahahaha....only driver is me or my daughter.....
predator carb guru 06-30-2019 02:48 PM
2 Attachment(s)
Got the new nitrous system and injection system....now to get some safety things updated (seat belt, trans case and bell housing, etc) and let this heat and humidity pass!!! WAY to hot here for me!!! Plan is to survive the summer, make sure the car is ready to go, and run again in September. Will finish tuning it on gas, then make the switch to alcohol and test again. Can't wait to see what the difference in performance is, and how much difference there is in cooling! Nitrous won't be part of the test, as I want to see how it runs on gas vs. alky. Nitrous will get tuned later on when I'm ready to play!
454 Rattler 07-01-2019 09:09 AM
Keep us updated. This sounds interesting.
454 RATTLER
predator carb guru 07-14-2019 07:56 AM
Couple updates. Trans is out of the car and apart so case, bell, and flex plate can get recert done. Was going to take it to JW already but work got in the way, vacation coming up, so it's gonna be a bit before I get it done...good thing is between the trip to JW from my house, waiting for them to do the certs, then back to the house, put it back together, and put it in the car is a one day deal.....long day, but one day regardless. Seat belts also expired, so got the new set, just need to install them. Being lazy today so I'll work on that later. Got new radio connections and helmet set as old one stopped working....new connector is a lot shorter so need to figure out whether or not I'll have to move the radio. Cable from the antenna is only so long so I need to figure something out other wise I won't be able to plug my helmet into the comm....
While the trans is out, also need to figure out routing for fuel shutoff cable so when I install the injection, I have it routed....
Checked on a local place to modify my fuel tank to increase capacity.....won't be calling them back. They wanted $1600 plus materials!!! I called Mike Bos (car builder) and they said just send them the old tank, they will build me a new one with whatever bungs I want, and send both back for $400. You can guess what I'm going to do.....Mike even said they could do it in about two days and have it back to me.....
Inductions Solutions will be welding the new bungs on my intake. They aren't that far from here, quick turn around, and work is second to none....great price too, only $200 and they will blend the bungs into the runners as well.
I'm going to get the car back together and make some passes on gas in september, finish the tuning so I have something to compare to. Then off comes the gas stuff, on goes alky stuff, and back to the track.
Two biggest things I'm excited about, regardless of outcome of testing is MUCH cheaper fuel and lower fuel bill, and no more overheating issues......One of the best qualities of running alcohol is that engines actually have trouble building heat.....that's not a bad thing.....
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
