My roadster build - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2008, 02:54 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
My roadster build
Finally figured out how to get a pic on here. This is the '27 roadster I worked on for several years. Started with the glass body, which I split down the middle and widened 8". You can see the added width in the firewall and on the rear apron. Frame rails were 2' x 6" mild steel. Made saw cuts through 3 sides to bend them, then welded up the saw cuts. Rear diff, rear suspension (Satchell link 4-bar), wheels and brakes from a Continental Mark V. The 2.80 gear was retained because I was building this car as more of a cruiser. I had a 4.30 pig under the bench, but decided it would be too much. 429 and C6 from a '68 Ford. '29 A radiator shell surrounding a 4-core Walker copper/brass radiator. Self-designed and built IFS made from 1 1/8" chromoly tubing, using Chevy pickup control arm bushings and Aldan Eagle coilovers. Mustang II power rack and pinion. Built the car on a 117" wheelbase so I would have plenty of room for the 18", 7-blade OEM steel fan, viscous drive and shroud. You may be able to see that all the added length is between the front of the motor and the radiator. I had a 2 1/2-gal Moon tank that was scheduled to go in between the frame rails at the front.
Measured with a dial indicator, zero bump steer through 9" of travel (4 1/2" in bump, 4 1/2" in droop) in the front suspension. As viewed from the front, the inner tie rod pivot point lined up with the lower control arm mount at the frame and the outer tie rod pivot point lined up with the centerline of the lower ball joint. Everything swung through the same arc, so it was all happy with each other. 3 1/2 degrees of camber gain at full bump. Steering arms were fabricated from mild steel and heli-arced to the Lincoln spindles with additional gusseting.
The 1 1/2" square tubing you see at the bottom is the floor of the car. I built it to accomodate a 6'-6" driver with plenty of elbow room afforded by the 8" width addition. A Jerry Kugel 90 degree brake pedal assembly was mounted under the dash, using a 'Vette master cylinder and Midland-Ross booster. I had seats from a VW GTI and windshield from an MG that weren't mounted yet when this pic was taken.
New spring cups were fabricated and welded in at the rear to accomodate Speedway 5" diameter coil springs so that the car could be dialed in. Their springs are available in rates from 125 to 600 lbs/in.
The 429 looks lost in there doesn't it. I'll try to post some detail shots of construction if I can find the pics.
Old 07-27-2008, 03:40 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
That early A shell looks good on the 26/7 body I'd like to see different angle pics of the wide body...sounds cool and from what I see, the peoportions look good so far.
26/7 bodies are cool any way you look at them
Old 07-27-2008, 04:08 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Thats good of you to post that so the guys can see a real rod in progress..Good job..
Sam
Old 07-27-2008, 07:31 PM
Wiki Edits: 326
One thing I forgot to detail is the seats. These were from a '86 VW GTI and were the best fitting seats I've ever sat in. I found them in a boneyard car. Black leather and not a scratch on 'em. Someone had unbolted them and they were just sitting loose in the car. I soon figured out why the guy didn't go ahead and take them. The seat tracks were made into the floorpan of the car, so they didn't come out. I guess he figured they wouldn't work without the tracks. Not so, kemosabe!!! Gave the man $100 and loaded them into the back of my truck.
I went to another boneyard and discovered 8-way power seats in a couple of '93 Tempo's. Scored two driver seats and tracks for $75. Didn't give a hoot about the seats, it's the power tracks I was interested in. These particular seats are neat because there are only two wires to the motors. Hot and ground. The OEM seat switch is mounted at the front of the seat. It was pretty easy to tear the seats off and adapt the VW seats to the Ford tracks with some scrap steel I had and was made double cool by fabricating brackets on the front of the VW seat frames to mount the actuating toggle. Bingo, two nice 8-way power buckets for $175 and a little work.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
1932 chev roadster campaq Introduce Yourself 2 03-18-2006 11:50 AM
32 roadster blueprints scottvnz Body - Exterior 8 03-11-2006 05:56 AM
what size motor for a 32 roadster moldmaker Engine 46 12-07-2005 07:31 PM
Need help with a 351W build Nico Engine 6 06-15-2003 10:07 PM
