need help lowering my 57 3100 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2011, 05:52 PM
Going to lower my 57 3100, and I need some info. How much further do I need to lower the rear of the truck to level it with the front? I have decided to go with a more traditional lowering job using mono leafs 3 in front 6 at rear and a 3 drop axle. I have a few more questions, first its looking like if I stick with a 15 rim Im going to have no scrub line clearance. Ill be 1/4 short (bottom of stock axle to ground 8, minus floor to bottom edge of rim 5.25, minus 3 of drop axle). So if I go with a 16 rim I should have of clearance on the scrub line. Is this enough clearance, seem like its too close? Should I go with a 17 rim? I dont want huge rims on the truck as Im going with a more traditional look. What are you guys running for a set up on your solid axle lowering job? I would like smoothies also but do they make them with a cap that will fit over the stock 6 lug front hub? What size rims, width, back spacing and diameter, are you using? The lowering is going to be done in stages starting with the springs and then later putting in the drop axle. Im sure the 6 drop in the rear is going to be too much and will need blocks to bring it back up, What size blocks are you using ? Next the steering, the drag link is going to be an issue right? What will I need to do to correct this? Any other issues Im going to run into with the spring part of the lowering job, and when its time what issues will I have with the drop axle install? Thanks for the help guys.
Old 10-05-2011, 09:01 PM
Hi.
Try eatonsprings.com and they should be able to tell you what you need to know.
...also: read their article in "Tech Info" titled "What are the differences between mono-leaf and multi-leaf springs?"...very enlightening.
Good luck with your project.
Dave
Old 10-06-2011, 11:38 AM
ogre's Avatar
the 'Duracell Project'
my 58 is on stock springs in back with the axle flipped on top of the springs. this will halve your stock ride height. i did have to c-notch the rear.
i have a fatman mustII frontend.
Old 10-06-2011, 11:40 AM
ogre's Avatar
the grass pic is a little deceiving
also check out the very active 55-59 chevy truck thread in this forum
454 going into my 53 3100 chevy53 Engine 10 01-18-2013 08:24 PM
new guy, new project, '55 3100 evilbeef54 Introduce Yourself 1 01-19-2011 03:28 PM
56 chevy 3100 235 hottrodz Engine 1 04-26-2007 12:46 AM
IFS Install, 51 3100 slstusmc Suspension - Brakes - Steering 3 07-24-2006 05:22 PM
53 3100 flyfish Introduce Yourself 3 01-26-2006 07:01 PM
