Need help on my 1938 olds coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2018, 09:42 PM
38 old coupe's Avatar
Last journal entry: Electric windows
Hello I have a 1938 Oldsmobile business coupe and Iím doing body work and I have a question on
When I do the doors and trunk should I adjust and blend in the doors to body with the door seals or with out the seals for the doors and trunk?
Thank you kelly
Old 01-03-2018, 11:17 PM
I always adjust the doors and trunk without the seals and then put them in for final tuning. Often there is some pressure as the rubber is too thick or too hard. If you adjust first and know they fit, then you add the rubber and when it's not too cool all that does is tell you it's the rubber and not your fitting, you know what I mean? So at that point, you move the striker out (or on a late model car leave it on the first catch) and leave it with the doors not fully closed for a few days then come back and move the striker in a bit, you slowly mash the rubber until it fits properly.
I have been doing that for years with good results.
The Following 2 Users Say Thank You to MARTINSR For This Useful Post:
22george (01-04-2018), JohnnyX (01-08-2018)
Old 01-04-2018, 07:32 AM
BillPac's Avatar
38 Olds
Love the car! What's the powertrain? From the pic you posted, looks like SB Chevy with 3 deuces . . .
Old 01-04-2018, 08:12 PM
Billpac
Yes it was a sbc 327 small jernal crank with Tri power but I decided to go with a 6.0 gm ls motor that’s 335/350 hp stock and going to change the crank and install a turbo on later shooting for 500 to 600 hp.
Martinsr
With out the door seals it looks good they match with a straight edge
With the door seal upper on it still matches good but if I add the door bottom seal it pushes out the door bottom 1/4 or so but the upper is flush when I adjusted my striker all the way in and shut the door hard .
Also I have bear claw latches installed
With out the strike on when I close the door I can feel it binding at the door bottom and lower seal .
What I’m thanking no of doing is taking some clay and rolling it up and installing it to the place where the lower door bottom seal goes and make the adjustments to the rocker to get the clay all the same thickness all the way across it.
Since I had the rockers off and thought I put them back In The same spot they came from.
ID:	397242   Click image for larger version
ID:	397250   Click image for larger version
ID:	397258   Click image for larger version
ID:	397266   Click image for larger version
The Following 2 Users Say Thank You to 38 old coupe For This Useful Post:
123pugsy (01-21-2018), 22george (01-05-2018)
Old 01-05-2018, 08:05 AM
S10xGN's Avatar
Gotta love a turbo!
Nice car! I'll be interested in what Brian says about the bottom door gap, my Maverick has the same issue. Only aftermarket weatherstripping is available and it pushes out the door bottom. The doors also need a good slam to close...
Russ
Old 01-08-2018, 06:47 PM
I cant think of any better car than that. I'm a sucker for Olds though.
Old 01-08-2018, 09:08 PM
Its came a long ways .
Just wish I could get more time in the shop my job has been crazy was told it was a 40 hour a week job and a little over time .
But turned out to be a crazy over time job 10 and 12 hour days and min of 8 on sat and supposed to be this way tell the end of sept when we will ne topped out.
Hereís a few pics of some of the work on the coupe and before pics itís sitting on a 38 Chevy coupe frame
ID:	397842   Click image for larger version
ID:	397850   Click image for larger version
ID:	397858   Click image for larger version
ID:	397866   Click image for larger version
ID:	397882   Click image for larger version
ID:	397890   Click image for larger version
ID:	397898   Click image for larger version
123pugsy (01-21-2018), JohnnyX (01-08-2018)
Old 01-08-2018, 09:20 PM
More pics of the coupe
ID:	397938   Click image for larger version
ID:	397946   Click image for larger version
ID:	397954   Click image for larger version
ID:	397962   Click image for larger version
The Following User Says Thank You to 38 old coupe For This Useful Post:
Old 01-08-2018, 09:46 PM
More pics off phone and one of the Willyís pu I was doing before I got a divorce and the ex got it
ID:	398002   Click image for larger version
ID:	398010   Click image for larger version
ID:	398018   Click image for larger version
ID:	398026   Click image for larger version
Old 01-08-2018, 09:48 PM
I love that grill. Yeah you have brought it a long ways. Keep up the good work.
I know the feeling. I did 6 12's for a year before I just decided whats the point in life that way and found something else.
Old 01-19-2018, 02:48 PM
Jmo23's Avatar
HELLO I have a ??? I have a 1939 Buick do any one know ifís the small windows on the side open up....
Old 01-20-2018, 07:01 PM
On my Oldsmobile they donít they are fixed windows.
Not sure about the Buick
Old 01-20-2018, 07:29 PM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
I love your car Man. Its a business coupe isn't it?
Your doing some nice looking work too.
Old 01-20-2018, 07:36 PM
Wiki Edits: 11
I don't know for sure if your talking about the vent or the 1/4 glass but it depends, a coupes back glass should roll down (not always) but a business coupe wont because theres no back seat so no need.
Old 01-20-2018, 08:48 PM
Thank you deadbodyman been working on it for 15 years off and on.
Yes itís a 1938 Oldsmobile business coupe.
At first I was going with a 327 small block Chevy small joineral crank tripower but then decided I would get more hp and fuel mileage from a gen 3 ls motor so I changed to that direction 325 to 350 stock with the ls and Iíve been thanking of putting a turbo charger on it also and tune it for 500 wheel hp just by changing the cam and a tune and injectors and still could be a daily driver if I wanted to. Now my job has me working long hours and 6 days a week tell July some time so I will stock pile parts tell I can get time to work on it.
I told the wife one Sunday a month Iím working on the coupe itís better then nothing.
I bought some clay and surian wrap to put the clay in I will roll it out to about a 1/2Ē the entire length of the lower door seal and find out where my door is binding when I close it that leaves it the door bottom sticking out a 1/4Ē
And then I will reshape the rockers to have the right dimensions when it closes to seal up I had the rockers off and thought they was I. The same place but I guess something is off.
1938 Dodge Coupe purple person Introduce Yourself 2 01-09-2016 07:45 PM
1938 chevy coupe RodgerDodger Interior 3 10-01-2015 04:52 AM
1938 chevy coupe fender RodgerDodger Body - Exterior 4 11-30-2014 07:08 AM
1938 Pontiac Coupe dnkvette Suspension - Brakes - Steering 7 02-04-2010 10:19 PM
1938 Pontiac Sport Coupe rchrischris38 Introduce Yourself 15 05-28-2008 06:01 AM
