Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - NEED HELP TODAY!!
Old 12-23-2001, 09:44 PM
liquid_larry liquid_larry is offline
Post
Just wondering if you have little tiny holes in your fingers yet. You do need tape on the ends of the hose,I've used masking tape pulled as tight as I can get it,you only want enough to keep it tight,2 wraps at most. If the ends are mushroomed out you will probably have to trim the hose,if you do, tape the ends first and use a chop saw or a fine tooth hack saw to trim it.The end will thread onto the hose,check to be sure its on as far as it needs to be,it should seat in the fitting.Oil the inside of the hose and the tube that goes into the hose, turn and push together as far as you can and tighten with wrenches until the hex on both fittings are snugged together.Hope that helps.
