Need to shorten rack & pinion 12". - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 09-08-2018, 08:54 AM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
suspension design.
There is a lot more than Bump steer, You probably not be road racing the rat but here is some more good info from fat man
https://www.bing.com/videos/search?q...4CEF7&FORM=VIR
A good friend is Bruce Cambern, The retired head of Ford Racing, He was 2 times Nat't champion with his March open wheel car and still races his much modified 427 Cobra. He spent a lot of sunday afternoons on Ford's suspension computers when replacing the suspension on the Cobra
The Following User Says Thank You to timothale For This Useful Post:
de_greaser (09-09-2018)
  #47 (permalink)
Old 09-09-2018, 02:09 AM
de_greaser's Avatar
Good Stuff
Timothale, Thanks for the link to the Utube video. I watched it 2 times and will probably watch it again. I believe I will be OK with my DIY “cradle rack & pinion” because I haven’t changed any pivot points, steering arms, control arms or tie rod locations. If the Rat develops some bump steer then it had bump steer from the factory. Where’s that Thank You button? Here’s the latest pic.
  #48 (permalink)
Old 09-09-2018, 05:23 AM
Did you lose any turning radius with changing to a rack. E.g. now you cannot make such tight turns.
  #49 (permalink)
Old 09-09-2018, 06:19 AM
fiftyv8's Avatar
Just wondering how you went about determining the rack position?
Any handy hints...
  #50 (permalink)
Old 09-09-2018, 08:36 AM
Wiki Edits: 27
Safe is fast
another good educational series is Safe is fast.
google safe is fast youtube
When Bruce set the road race track record with his cobra at MIS all 4 wheels were pointing directions, set each wheel where it had the most effect on a part of the track and not reduce the total for the lap time.
I got a real education driving a 63 Falcon sprint that had a Cobra kit engine parts installed, the front end would lift and I had to crank the steering wheel 1/4 turn to keep it going straight, I was accelerating on a city street (dumb things kids do) when someone backed out of their driveway in front of me. Lucky, When I stepped on the brakes and the front end setteled the car went the right direction and turned away from the car in the road. AND when I was driving my Buick nailhead powered Willys set up with a drag race rear suspension and got into a hard turn and the rear suspension was doing the steering.
  #51 (permalink)
Old 09-09-2018, 08:48 AM
Wiki Edits: 27
Rack position
Start with the car at factory ride height. If you lower the car the pivot arc is in a different part of the curve and you can move the rack to compensate, When 5.0 Mustangs are lowered you can buy tie rod at steering arm connection spacers . That doesn't move the rack but changes the arc'.
The WIKI article I references on earlier post # 9 had some discussion about rack placement.
  #52 (permalink)
Old 09-09-2018, 09:53 AM
Wiki Edits: 27
hria video's
If you google
hria education day
then click on video's
there is a lot of good info from SEMA companies that make after marked parts
  #53 (permalink)
Old 09-09-2018, 03:14 PM
Good advice on getting the A frame and inner tie rod pivots all lined up to avoid bump steer. For future reference any rack and pinion shortening is all done on the end opposite from the pinion. Attached is a picture showing the limit of how far you can narrow a MII Rack and Pinion.
Name:	Narrow Must II 3.jpg
r&p, rack & pinion, rack and pinion
F1 rack and pinion harley1953 Suspension - Brakes - Steering 2 08-08-2013 05:04 PM
Mustang II rack and pinion, pinion Jim H Suspension - Brakes - Steering 3 02-23-2012 12:58 PM
S-10 with rack and pinion fierosum Suspension - Brakes - Steering 3 07-03-2008 08:32 AM
rack and pinion Gassed 64 falcon Suspension - Brakes - Steering 2 09-08-2004 04:47 PM
Rack and Pinion bigvofnash Suspension - Brakes - Steering 3 08-11-2003 12:13 PM
